duals or no duals
Old Sep 23, 2009 | 11:13 AM
Z2887's Avatar
duals or no duals
Im back in the 3rd gen game. Ive had 4 Camaro's and a TA. I see now quite a few people running true duals. Back when I got out of it, I talked to a bunch of people that said I would be just as well off running the normal 3" single. Because running true duals there would be alot of bends. Some of which would be close to 90 degrees. They said with these bends the true duals wouldnt flow well at all. My 86 Camaro, ran a 12.30's through the single 3", with a Flowmaster Y pipe and truck muffler. Has anyone actually done a good comparison between the two. With no other mods being done ?
Old Sep 23, 2009 | 11:17 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: duals or no duals
i thought true duals, were nearly impossible on our third gens.
Old Sep 23, 2009 | 11:25 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have true duals and wouldnt go any other way.
Old Sep 23, 2009 | 11:34 AM
Z2887's Avatar
That was the last I heard too, and if you could get them on there they were so bent up they wouldnt do any good. I remember somewhere had a 4" single pipe too. Any ideas who/where that was ? Its been over 10 years since I messed with a 3rd gen. Uncapped my car went from 12.30's to 11.80s. So the single 3" was blocking it up quite a bit. I just dont want to go through the trouble and expense of putting on true duals, and them do no good. Thanks for the input guys
Old Sep 24, 2009 | 02:12 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Its my opinion that a properly designed y pipe will support all the horsepower you will ever need on the street. No sense in going with duals and dealing with the headaches and hassles.
Old Sep 24, 2009 | 03:22 PM
Z2887's Avatar
I agree. The problem with that is I run through the mufflers at the track as well. So I need the best I can get. Like I said before. I lost a half a second by running a single 3" vs. straight headers.
Old Sep 24, 2009 | 04:28 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
on a healthy motor you would probably see that difference with ANY exhaust vs. no exhaust.duals can be done by a skilled exhaust shop with a bender, i have 2 friends with it done.cant compare it though as the cars had no exhaust to start with.
Old Sep 26, 2009 | 03:45 PM
cvz6977's Avatar
Car: 89 RS
Engine: 355
Transmission: T5 B&M Shift kit with short throw
Axle/Gears: 3.73 Posi
Not impossible, just dificult. The bends aren't too bad as long as you don't go too big with the tube. Here are some shots of my 2.5" through a couple of thrush glass packs. http://s794.photobucket.com/albums/yy226/cvz6977/
Old Sep 27, 2009 | 02:46 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Actually, according to the pros, a 100% properly designed exhaust will make MORE power than open exhaust will. I wish I could remember the magazine that did the test, but they lost almost 20hp open headers vs a complete exhaust with regular mufflers.
Old Sep 27, 2009 | 05:52 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
That should be true especially with headers designed right with scavanging in mind. Tuned exhuast is harder to do with the limited space that we have though. A friend of mine has a book for tuning the exhuast pulses to a certain RPM range but I'm not that far ahead with my car so I'm just going to deal with the Hedman headers that I have right now.
Old Sep 28, 2009 | 07:14 PM
BlueChevyZ's Avatar
Car: '84 Z 28 RIP, Red 87 Iroc
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: no more pegleg
do a search of mw66nova, he's done both duals and single 4"
Old Sep 28, 2009 | 07:52 PM
Stephen's Avatar
Car: 87 GTA
Don't forget....In none of the 50 states in the USA, will a true dual exhaust be street legal.
Old Sep 28, 2009 | 08:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't see why it wouldn't be on a dual-cat car?
Old Sep 28, 2009 | 08:11 PM
Stephen's Avatar
Car: 87 GTA
Technically, the cats cannot be moved.
So yeah...You could run 2 exhaust & 2 cats BUT...They must remain the stock location, both on the passenger side.
Dual (two pipes) exhaust? Yeah.
"True Dual", in regards to what most people picture (1 pipe per side of the car)? No.
Old Sep 28, 2009 | 08:12 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
i say go duals, they're great. about to do them on my 84.
Old Sep 28, 2009 | 08:16 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
looks good, hows the ground clearence?
Old Sep 29, 2009 | 06:08 AM
Z2887's Avatar
Not much else on the car will be either. Luckily I dont have to worry about that too much. lol
Old Sep 29, 2009 | 07:14 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
what a fun debate....one that has been beat into the ground further than just about anything on tgo. yes, duals are possible, especially if you take your time and mod the transmission crossmember, or not the subframe for the exhaust to make it's way around the transmission without going below the plane of the subframe, which is why people struggle with clearance.
as far as one over the other, it's hard to say based on the info given. if you have an 11.8x car then i'd say you would benefit from going to a single 3" to a true dual 2.5" system, but i also think you'd gain some serious number just going to a really well done y-pipe and a single 4".
what are you running for headers? if you're planning to do any of this, i hope you've budgeted longtubes if you don't have them yet, because you're just spittin' in the wind if you are planning to keep shorties.
couple of pics:
hedman longtubes, dual 2.5" pipes into a flowmaster y-collector, single 3.5" dynatech splitflow muffler:
back on the ground:
Hawk's ls1 swap headers, dual 3", flowmaster y-collector into a single 4":
back on the ground:
Old Sep 29, 2009 | 07:16 AM
mw66nova's Avatar
Engine: 7.0L
dual 2.5" x-pipe w/ t5, over the crossmember:
dual 3" xpipe auto:
look into the benefits of crossover pipes, and y-collectors with torque tubes. i believe the single 4" will yeild better results than a dual system as long as the y-pipe looks like what i've posted. there is a scavenging effect created much like the scavenging effects at the collector on the headers.
Old Sep 29, 2009 | 07:22 AM
Z2887's Avatar
Cool. Thanks for the input man. I have Hooker Super Comps.
Old Sep 29, 2009 | 08:18 AM
cvz6977's Avatar
Car: 89 RS
Engine: 355
Clearance is great. I have it tucked almost completely in the stock position, that's why it dumps out on the same side as opposed to one pipe on each.
Old Sep 29, 2009 | 09:11 AM
Z2887's Avatar
That was my original plan. I remember seeing in the back of Super Chevy or something a 4" cat-back. Someone still sell those or is custom the only way to go now ? Im starting to remember why I went to a .......Dont kill me please... fox body mustang. lmao
Old Sep 29, 2009 | 01:36 PM
Z2887's Avatar
I was looking at this. I could probably have one made cheaper though.
http://www.hawksthirdgenparts.com/ca...techmuf-2.aspx
Old Oct 1, 2009 | 12:57 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
mufflex, in NJ.
3.5" and 4" systems.
http://www.mufflex-performance.com/brochure.html
Old Oct 1, 2009 | 10:39 AM
Z2887's Avatar
Originally Posted by RPOL98
mufflex, in NJ.
Yeah Mufflex is the same brand I posted. Im pretty sure I could have one made for less than 600 bucks.
Old Oct 19, 2009 | 03:34 PM
cvz6977's Avatar
Car: 89 RS
Engine: 355
My duals cost just under 250.00 including the glass packs.
Old Oct 20, 2009 | 07:28 AM
Z2887's Avatar
Exactly. I talked to my exhaust guy(My dads buddy). He said he could make me a 4" single with a Y pipe for 100 and me buy the muffler. He made the X pipe for my Mustang for 100 bucks too, and its flawless.
Old Jan 25, 2011 | 11:42 PM
ericg83z28's Avatar
i believe summit racing has a kit but i think is a small diameter size
Old Jan 26, 2011 | 08:34 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I've had the 4" and the true duals on my car, but made a number of changes apart from the exhaust to pick up more power with the true duals. The 4" actually has more area and would flow better if Mufflex offered a better muffler option with their kit. Otherwise ground clearance was not bad, the system fit very well.
True duals sound awesome. But the way our cars are configured underneath, it is difficult to route true duals from long-tubes without ground clearance issues. But with long tubes, ground clearance is poor anyway.
If you tune an engine for a full exhaust and just drop it off and run it on the dyno, especially on a fuel-injected engine, you might loose power until you do some tuning. Carburetors can better compensate for major system changes, but it depends a lot on your configuration and tune as to weather running open headers will gain or loose power.
Old Jan 26, 2011 | 10:41 PM
duf6's Avatar
Car: '86 z-28 with true duals
Engine: carbed 350
Transmission: t5
Axle/Gears: 10 bolt 3.42 posi
single exhausts sound like modded ricers to different extents thats maybe why someone wants an other exhaust setup
Old Jan 27, 2011 | 02:00 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
i have a SINGLE 3" Flowmaster system on my 5.7L L98, and i don't think it sounds like modded ricers.
mebbe the cam, headers, intake, etc has something to do with it.
sorry, took the video at night, no picture at all, forgot to get a flashlight, was in such a rush to reply to this. mebbe later i'll update it with a daytime video.
http://www.youtube.com/watch?v=O-wJB3N0k0I
Old Jan 27, 2011 | 08:03 AM
duf6's Avatar
Engine: carbed 350
Transmission: t5
i don't mean a single sounds bad, i even heard a neon that i think sounded pretty mean, i just meant it's a little diffrent sound between one pipe or two.
Old Feb 3, 2011 | 09:00 PM
1bdbrd's Avatar
Car: 1991 Trans Am
How does a carb better compensate for freer flowing exhaust?
Old Feb 3, 2011 | 09:22 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Someone said that single exhaust sounds like modded ricers? insane. No way. Ricers sound that way because 4 cylinder engines, 6 cylinder engines, 8 cylinder engines etc all sound different.
Old Feb 3, 2011 | 10:43 PM
duf6's Avatar
Engine: carbed 350
Transmission: t5
I didn't mean any 4 banger with a crap muffler, I meant a single exhaust on a built import can sound mean, but it's still a different sound,porshe and lambo's have v8's and v12's just a different sound.I wasent tryin to be a juice bag.
Old Feb 4, 2011 | 09:18 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
well you are.
Nah j/k. I understand what you mean now by your explanation. Cool man. I dont listen to any ricers but I know they dont sound like v8's. Because only v8's can sound like v8's
Old Apr 10, 2017 | 09:03 PM
Drone358's Avatar
couple of pics:
back on the ground:
back on the ground:
Heyy Heyy, on the first picture What cross Member is that!?? Has anyone made the Hooker Header Cross Member for the T56 work for the T5's??
Old Apr 11, 2017 | 12:03 AM
Alice89's Avatar
Yes, I just did last weekend funny enough. You have to use hookers adapter part # 71223003HKR
You also have to slot the holes of the transmount bushing plate (gold part) with a dremel; the bushing is a prothane part # 7-1604
You can see in the pic below where I slotted the bushings base plate to make it line up with the t-5 mounting holes.
Old Apr 11, 2017 | 05:35 AM
mw66nova's Avatar
Engine: 7.0L
the crossmember in the top picture in my post was a Skulte Performance crossmember, no longer available.
Old Apr 11, 2017 | 09:13 AM
Drone358's Avatar
Alice89... DUDE you're a life saver. Thanks for the Info man this helps a TON!! Ugh.. I can breathe now lol.
Old Apr 12, 2017 | 05:28 PM
Alice89's Avatar
No problem
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
