Exhaust clearance needed under axle
Old Aug 28, 2019 | 02:01 PM
jbander's Avatar
I have a 87 Camaro and spent a lot of time adjusting the exhaust system to get my best ground clearance without it rattling under the car. I ended up with only 1 1/2 inch clearance under the axle. It has a 2 1/2" exhaust system. Is that enough clearance. Thank You.
Old Aug 28, 2019 | 02:26 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Exhaust clearance needed under axle
Under the axle? the exhaust goes over the rear axle not under it.
Old Aug 28, 2019 | 09:39 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Aug 29, 2019 | 07:50 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Can you post a couple of pics of what you're describing here?
Old Aug 29, 2019 | 09:04 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You put the exhaust under the axle? Serious?!?!
Old Aug 29, 2019 | 09:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Under the axle is easiest and less bends for less flow loss, i have done it often. But 1 1/2 inches is way low with 2.5” piping. I had twice that clearance with single 5” exhaust
or am i reading this wrong...1.5” clearance from exhaust pipe to ground right? Or do you mean axle to exhaust pipe?
Old Aug 29, 2019 | 12:25 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
THIS IS HOW.
Old Aug 29, 2019 | 05:20 PM
jbander's Avatar
Thanks for responding, It's Axle to exhaust pipe that is 1.5" now and it is duel exhaust.---It seems to be a math problem,the floor pan is 5.5" of the ground . it's 2.5" exhaust and It is now 2.5+" off of the ground. I maybe can tuck another inch out of it ,either increasing the axle to exhaust number or the exhaust to ground number. It will be tight.
Old Aug 29, 2019 | 06:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Sounds like quite a mess...
Old Aug 29, 2019 | 06:25 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I vote for tucking it up tighter so that the axle can never droop. I mean if you're going to do it then why half-*** the job?
Old Aug 29, 2019 | 06:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
1.5” below axle should still be way more than enough off the ground. You ever see how low lower control arm relocation brackets sit below axle tube?. Even stock control arm, plenty of clearance. If you arent lower than that you shouldnt worry
Old Aug 29, 2019 | 07:41 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Control arms are attached to, and move with the axle. Exhaust is not. My axle will drop as far as the shocks will allow, which is a pretty long ways, when the car is on jack stands.
That's 200 lb of axle resting on the exhaust tubes, plus half the weight of the torque arm, control arms, and driveshaft, plus any remaining spring compression force at 180 lb per inch in my case.
Old Aug 30, 2019 | 07:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well obviously you wouldnt hang the axle up on jack stand with this setup lol on the road you shouldnt be getting that much suspension travel so the exhaust should be fine. I havent seen any issues on 3 setups i have done under axles
Old Aug 30, 2019 | 10:31 AM
jbander's Avatar
Fun group of supporters here, thanks for the response Orr89RocZ, I can raise it another inch and will let you know how it turns out. If I have a problem I have the option of side exit exhaust in front of the rear wheel well.
Orr89RocZ
Jul 20, 2012 11:42 PM
Bobby_80s
Apr 22, 2012 06:13 PM
brocknstock
Jul 30, 2009 01:17 AM
WhiteHawk
Sep 21, 2007 07:53 AM
CaysE
Jul 17, 2004 12:49 PM
