Brand new Cats now rattling
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
Happy Friday everybody,
I’ll be as descriptive as possible: My catalytic converters are now rattling within the last week, and they were replace 3 months ago. I run only 91 octane gas. Now if I replace them again my concern is it’s just gonna happen again unless I track down this problem. It is throwing a code as well (Code 32) I was going to run some sea foam through the fuel system and see if that would help clean the injectors but I’m looking for suggestions on tracking down this problem. Here are the things I’ve done in the last 3 months:
New: Spark plugs, wires, O2 sensors, fuel pump +filter, serpentine belt, rad hoses, thermostat, Fan switch, oil pressure switch, water pump, just to name a few.
Car: 91 Z28
Re: Brand new Cats now rattling
I did the seafoam treatment to clean the fuel injectors, I have to say I noticed a big difference when I pressed on the accelerator. A little white smoke came out, but I did notice the rattling stopped, probably because the honeycomb element inside might already be gone.
If that’s the case I might have to get new cats again. I think this time I’ll try doing the exhaust myself. I’m going to do one more treatment of sea foam just to be sure.
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Catalytic Converter Break In
- Start up the engine and let it idle until it’s warmed up. Do not rev it.
- Once the engine is warm, or after around 5 minutes, increase the RPMS to around 2500 for around 2 minutes.
- Return to idle and turn the engine off.
- Let the car sit until it’s fully cool.
Cat Break In
Bobby_80s
May 6, 2007 11:59 AM
ChrisFormula355
Sep 28, 2003 06:56 PM
