89 firebird wont run right please help
Old Mar 13, 2012 | 11:05 PM
schlegel94's Avatar
Car: 89 s10 89 firebird
Engine: s10 has 4.3 firebird has 2.8
i have an 89 firebird i do not have a reader but it only throws a code once in a while. but it has new idle air control sensor ,new throttle positioning sensor, new o2 senser, new maf sensor, has new fuel filter, recent coolant change, new radaitor hoses, new gold distrubutor cap and rotor, new wires, new spark plugs, new air filter, recent oil and filter change ,newer altanator, soon to be new fuel pump tanks droped right now. i think i got that all in it has a miss at idle and it will eventully miss until it stalls but it dont seem to miss when im driving it seems to have power takes off good but i have to keep rpms up at a stoplight or it will stall out can you please help its draining the bank throwing alot of money into it
Old Mar 14, 2012 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 firebird wont run right please help
But what codes is it throwing when it does?
Have you done any basic tests like fuel pressure , vac leaks , etc
Why did you replace all those part before 1st determining what your actual problem is ?
Old Mar 14, 2012 | 02:35 AM
schlegel94's Avatar
idk im getting a reader in the next few days but i belive its just the o2 sensor it only when i get down on it it runs rich. i got a one vaccum leak that im fixing but all needs to be changed. and idk thought i would eventully hit and miss but i have justt missed a few more detail is runs better when cold worse when hot
Old Mar 14, 2012 | 09:01 AM
torque_is_good's Avatar
you don't need a code reader and if you are getting an OBD2 reader then it can't read the codes from your OBD1 car
you need a very expensive code reader which can be purchased at WalMart, Staples, Office Depot, Dollar Tree etc. The last time I bought those code readers it was for qty 100 and it cost $1
here's a link to the more expensive code reader but you don't need to get non-skid
http://www.staples.com/Jumbo-Paper-C...product_525949
ps- there are many threads and sticky's on how to read codes
I've provided a link on where to get the tool
Old Apr 16, 2012 | 12:58 AM
schlegel94's Avatar
i am getting computer reader tommoro finalliy finished the fuel pump it ran better but she still misses i think its injectors ran it for 20 mins no codes tonight any ideas
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
armybyrd
Aug 10, 2015 09:23 PM
