92 Camaro V6 Exhaust Manifold Gaskets?
Old Nov 11, 2024 | 06:57 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I have my engine out so changing a few gaskets and seals. I pulled the exhaust manifolds off and the gaskets (don't remember the brand) with 30,000 miles on them are pretty much shot. What is the best gasket to get that will last much longer?
Thanks.
Old Nov 12, 2024 | 01:15 PM
Re: 92 Camaro V6 Exhaust Manifold Gaskets?
None.
AFAIK the factory hasn't used gasket on exh manifolds since the late 60s. What you're experiencing is EXACTLY why.
Just clean up both surfaces, use a flat mill file on the manifold if it's real rough to get it as absolutely flat as possible, and bolt em up.
Old Nov 12, 2024 | 02:36 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I have owned this car since new and so I know it did come from the factory with exhaust manifold gaskets originally. The surfaces are a bit rough and I can flat file them but still intend to go with gaskets. I just ordered some Mahle gaskets that appear to be better than the FelPro ones as near as I can tell and look closer to the original factory ones.
Chevyman84
Feb 26, 2007 09:18 PM
'86Twins
May 9, 2004 09:46 PM
25THRSS
Mar 29, 2004 12:23 PM
1986CamaroSC
Jun 13, 2003 12:25 AM
