A.I.R. emissions system question?
Car: 1992 chevrolet camaro rs
Engine: tbi 305 v8
i know theres already a ton of threads asking about the air emissions system, but i dont think thie question i have is on here.
so basically, i tried taking off those air injection pipes from my headers, because i wanted to free up some space, and ive also heard people say you can do that cause it frees some hp and gas milage, but i found out that was bs. i started getting codes, and the car runs like crap. so im putting those air injection pipes back on. but my question is i only have the pipes on the driver side headers right now, (which is where the 02 sensor is located) but not the passenger side ones. i though just having that one side with pipes would fix it, but its throwing a code saying its running too lean (which is code 44), and im getting a code for either an alternator fault, or an egr fault, (code 53).
now i know theres 2 ports on the air pump diverter valve, and i know that the right port is supposed to go to BOTH injection pipes, but i just have that one port running to that one on the driver side. is there too much air going through those pipes that makes the 02 sensor tell me its running too lean?
sorry if my descriptions are too confusing, i tried my best.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: A.I.R. emissions system question?
Removal of the A.I.R. shouldn't throw any codes. You have some other problem...
Not related.
Sounds like maybe you disturbed an electrical connector or a vacuum line somewhere along the way.
Go back and check your work CAREFULLY. Leave behind your personal pride about what a good job you did.
Engine: tbi 305 v8
are you sure? i have a haynes repair manual, and im looking at the symptom for rough or erratic idling, (which i have) and it says defective or damaged emission compnents could cause it. i have a hard time beleiving the system will be fine without the amissions system, specifically because the o2 sensor tell you if your air/fuel ratio is lean or rich, and im thinking the extra air blowing into the headers would be coded in with it. you know what i mean?
Car: '89 GTA
Engine: ZZ6TPI
If your AIR system was injecting into the exhaust manifolds all of the time, then you would definitely have an issue with the O2 sensor reading correctly when the ECM goes to closed loop.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Having it partially hooked up could be a problem. You should either have the entire system hooked up, or the entire system removed with holes plugged. As long as the side with the o2 sensor is plugged nice and tight, removal won't throw any codes and it doesn't affect how it runs.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Removing a properly functioning emission control system on a stock L69/TPI 3rd gen that is new enough not to have the pancake style catalytic convertor with the pellets in it doesn't make the car run better or have a significant amount more power. I don't even think any of these cars equipped with these engines had that old style catalytic convertor.
Removal Equals
A.I.R. system = About 1.3 HP at 5,500 RPM.
EGR = No power gain and reduced fuel economy.
Charcoal Canister & Evaporative Emissions System = No power gain and stinky garage.
Catalytic Convertor = About 5 to 8 HP L69, LB9 H.O. Cam, L98 with a H.O. single cat exhaust system and a stinky car.
Removal Equals
Car: 1984 Z28
Engine: 305 HO
Transmission: 5 Speed
Axle/Gears: 3.23 Truetrac; was better w/ 3.73
Removing AIR greatly improves maintainability of the engine.All are correct it will not cause a code.
Yeah A.I.R. gone cleans up the engine bay and makes sparkplug changes so much easier.
G92Joe
Dec 24, 2000 04:44 AM
