Need help with header bolts....
Old Feb 11, 2002 | 02:28 PM
CamaroX84's Avatar
Well, I put on my headers last summer, and I forgot that you have to tighten them every so often. I went to tighten them last week and one of the bolts was only hand tight, and another bolt was completely missing. Is there any kind of very high temp loctite (removable kind) or something else I can use? What about lock washers? How often are you suppose to tighten them? Any help would be greatly appreciated. Thanks.
Old Feb 11, 2002 | 11:05 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
put a little permatex on the threads. A little is usally enogh to keep them from backing out.
Old Feb 11, 2002 | 11:22 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Re: Need help with header bolts....
The loctite you want to use is High Heat (red). Unfortuanately, it's about $7 for an itty bitty tube. It'll last you through the header bolts though. Fortunately, $7 is also worth the money when you're forced to replace gaskets, bolts, etc. Some header bolts do come with lock washers...that's fine. Use loctite anyway. I usually do this: Put header bolts on with loctite and new gaskets. Tighten from inside out. Immediately warm engine. Tighten all the bolts while hot...yuck. Let it sit for a night. You shouldnt have near the problems as before if you follow these steps. See ya.
Old Feb 12, 2002 | 01:37 PM
chevyboy07 91's Avatar
use the Permatex brand orange RTV...its really high temp and works like a charm.....just a little and youre OK....cheap stuff too!
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
