Will Slp 1 3/4 headers work with Trickflow 23* heads?
Old Feb 21, 2002 | 06:25 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Do they clear the spark plugs?
Old Mar 5, 2002 | 10:23 AM
rgreen78's Avatar
I am wondering the same thing, does anyone have trickflow heads with slp headers?
Old Mar 24, 2002 | 10:23 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Just installed the SLP headers...and the plugs clear fine on the 23* trickflows. WOOHHOOO! IM very impressed with the quality of these headers.
Old Mar 24, 2002 | 04:44 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
You're welcome
Old Mar 24, 2002 | 06:48 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Hey Paul....One of my converters was totally blocked, I think thats part of the reason why my car only made 306 rwh. Should have some new numbers within the next few weeks.
Old Mar 24, 2002 | 11:41 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Very good to hear! And I can only imagine what kind of power you will make without having half the engine choked off!!!
Also, what plugs are you using Mike? I am running the A/C FR3LS ones in mine and they are pretty damn short so I don't forsee a problem when I get my SLP 1 3/4s.....
Thanks,
Matt
Old Mar 25, 2002 | 01:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My dad has an 88 IROC in his shop right now with Trick Flow heads and SLP 1 3/4" headers. Spark plug wires and access is just fine.
Old Mar 25, 2002 | 03:41 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Its all still in pieces, I can send you some pics when it gets put together :lala:
Should be running soon though
Old Mar 25, 2002 | 09:03 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Ive swapped a few motors over the years, but ive never had so many stupid little problems as ive had with this buildup. The cats melted when I first installed the engine, it was running really rich. I replaced the muffler because of all the junk in there. The exhuast has been blocked from the begining, in one way or another, I hope i didnt burn the valves. I think this has something to do with the detonation problems ive been having.
Matt....I tried to send you an email yesterday but got side tracked. I will have to check but IM pretty sure IM using the exact same plugs as you are. The only one that was kinda close was the number 8 plug. I have the ones with no airtubes, I can finally run my plug wires over the valve covers and straight down to the plugs. The passenger side wires were always a pain on the TES, and one of the passenger tubes ran right next to my AC box building alot of heat there. I did have some problems with the steering shaft making contact with the driverside header tube. Just barely though i just loosed the two bolts that hold the shaft to the firewall, pried it over. A swift blow with a big hammer would have worked as well the contact was minor.
8T8IROC...I would like to see those pics...
Old Mar 25, 2002 | 11:47 PM
Matt87GTA's Avatar
Cool cool, Mike.
Ghettobird52
Jul 5, 2024 11:18 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Reddeath210
Oct 6, 2015 08:20 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
