SLP header install?
Old Feb 25, 2002 | 07:58 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
SLP header install?
hey guyz next month i'm getting the SLP 1 3/4 headers and Y-pipe.. hows the install on this? nice and easy? any clearance issues? and whats the installation kit that SLP sells? do i need to buy this also? i think its the gaskets and bolts but i don't know its like a hundred bucks more so i wanna know if i need it or not, or do u just need the headers and y-pipe? thanx for ur help in advance.. mike
Old Feb 25, 2002 | 10:42 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'd suggest you get it, especially if you are getting headers with AIR tubes.
The SLP installation kit comes with everything you need (bolts, gaskets, RTV, etc) in a box. This way you dont have to waste time running back and forth to a parts store.
They may try to sell you the Y-pipe to cat adapter. I would NOT recommend buying this since an exhaust shop can make and install one for less $$$
Old Feb 25, 2002 | 05:38 PM
89BlueTA's Avatar
I thought the install was a little worse than normal, I had some clearance problems on the drivers side with the brake lines and steering shaft. I also had to take the valve cover off on the drivers side to get the header in. On the pass. side I just had to take out the motor mount bolt and jack up the engine a little.
GL
Nick
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
theurge
Aug 21, 2015 12:46 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
drathaar907
Aug 6, 2015 04:20 PM
