Mr. Gasket Copperseal header gaskets
Old Mar 11, 2002 | 12:20 PM
IROCBUFF's Avatar
Car: 1987 Z-28 IROC-Z
Engine: 5.7
Has anyone had trouble getting Mr. G's Copperseal gaskets to seal the center exhaust tubes of their headers? I was told these are the "best you can get" but have had trouble getting them to seal on both sides of the engine (TPI 305).
I am going back to a more tried and true conventional gasket, but wanted to know if there was some special way to put them on.
Thanks for any inputs!
Old Mar 11, 2002 | 07:30 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
I had them installed and have not had a problem with them.
Old Mar 11, 2002 | 07:59 PM
jayman350's Avatar
I had a problem with them as well. I bought fel pro manifold gaskets and that solved the problem. Its a 6 piece set (one for each group of exhaust ports 1,2,1) they only cost me like 12 bucks or so and they work better than the $60 copper ones
definately recommend them, sorry i don't have a p/n
Old Mar 12, 2002 | 07:59 AM
IROCBUFF's Avatar
Engine: 5.7
Cooperseal Gaskets
I removed the Copperseals after trying several methods of torquing the headers. Close inspection revealed that the embossed ridge between the center ports would not seal. I replaced them with steel core "paper style" gaskets and Permatex Copper gasket sealer and it has done the trick. I am not sure why I could not get them to seal. Maybe it is the design of the Hooker Shorties or the 5.0 head itself. I checked both for straightness prior to installation and they appeared to be ok. Maybe when the headers are torgued they distort slightly.
Thanks for your inputs guys!
IROCBUFF
gta892000
Aug 11, 2019 11:16 AM
Metalizer
Sep 13, 2015 12:56 PM
hdis2002
Sep 8, 2015 02:52 PM
09ave
Sep 7, 2015 06:03 PM
tgp1990
Sep 4, 2015 06:24 AM
