Pro's and Cons: Dumped vs. Catback???
Old Mar 12, 2002 | 10:41 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm thinking about going with dumped exhaust if I get headers. I'm just wondering what you all think about this. It seems to me these are the pro's and con's I can think of right off hand...
Catback:
more expensive
quieter(probably)
looks(tips exiting in rear of car, etc etc)
Dumped exhaust:
cheaper
loud(most likely)
no tips to deal with(nasty rust, cleaning, lining up)
more power?
Dumped exhaust is pretty much the headers, y pipe, cat(if you wanted), muffler, and a turn down on the muffler right? I dunno, which would probably make more power? I'd think that since the catback goes farther it would probably make more backpressure and therefore more torque? And the dump would have less length to travel and have more high end? Also, my dad doesn't like the idea of the exhaust just coming out under the car. Would that be a major problem? Like exhaust fumes leaking into the interior or anything like that? Can anyone recomend a good muffler if I did dump the exhaust? Are the dynomax 'race mufflers' good, aren't they like a glasspack? Thanks.
Old Mar 13, 2002 | 09:58 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Pro's and Cons: Dumped vs. Catback???
I'm pretty sure dumped exhaust doesn't have a muffler, but could be wrong. Also backpressure won't give you more torque, backpressure is bad no matter how it's looked at, you're confusing it with velocity.
Old Mar 13, 2002 | 10:53 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I would go with the exhaust system.
Old Mar 13, 2002 | 11:31 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Another thing to consider is if you have to go through emissions or not. Here in AZ, if you don't have an exhaust pipe they can see without getting "under" the car, they won't even test you. It's stupid but they must be afraid of getting dirty or something.
Old Mar 13, 2002 | 08:42 PM
Hg's Avatar
Hg
Car: '87 Z
I'm pretty sure dumped exhaust still uses a muffler... don't it? I know like 2 or 3 people that have dumped exhaust and it's still got a muffler.
Old Mar 13, 2002 | 09:20 PM
cort351w's Avatar
I'm dumping my duals before the axle (turning the turndowns outwards to cut down on drone--I figure it will be like two cutouts). Anyway, I'm using mufflers and cats.
Old Mar 13, 2002 | 09:40 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Eeep! My tips are about halfway between the rear axle and the rear bumper... will they test that?
Old Mar 13, 2002 | 10:21 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i am dumping mine. headers, the ypipe, a straight piped cat an i pipe with a flowmaster delat force two chamber race muffler and a turn down right before the rear axle
Old Mar 13, 2002 | 10:22 PM
BAK12484's Avatar
i guess you could argue what "dumped" means exactly... but my plans for when i do my exhaust are headers coming to an x-pipe, no cats (no emission tests in michigan...woo hoo!!), and then a muffler on each exhaust pipe, which will then be dumped before the axle. The way i see it is dumping the exhaust is a lot easier then bending a pipe for over the axle.
Really I dont think there would be too much of a performance difference as long as you get a decent cat-back......so its more or less perference and how much money you wanna spend....just remember you have a lot of options to choose from so make sure you get what's right for you
Old Mar 13, 2002 | 11:35 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
i think it would be both easy and cheaper to go with the cat-back style, althought dumps are cool
Old Mar 13, 2002 | 11:53 PM
the pipe is like 82 bux and a muffler is like 60 bux. so thats 140 + labor to weld it up. a hooker cat-back is 200 + labor to weld it up. i think the dump may be a lil cheaper. altough i really like my current dual tailpipe setup
Old Mar 14, 2002 | 03:37 PM
Hg's Avatar
Hg
Car: '87 Z
Can anyone tell me about the exhaust fumes? Like if I have it dumped underneath the car, will I have problems with fumes leaking into the interior? I don't really want to die ya know? I want the sound/tone that straight pipe made on my 305 (it was cut just before the axel) but about half as loud. Can anyone recomend a good muffler for this?
Old Mar 15, 2002 | 12:36 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
my dumps had a muff on it in my 71 camaro
the fumes where not that bad unless you are sitting still for a while then they get in the car
other then that I had an exhaust leak from my header that gave me a little fumes but before that I didn't notice any fumes in the car
and as for performance the only thing I could think of is with the shorter exhaust pipe you might have it better tuned for a higher rpm motor though I dont think you would get much difference from just that
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
