Tailpipe Expanders: All that can help please do!!!!!!
Old Mar 17, 2002 | 07:05 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys, I am looking at tailpipe expander tools for my flowmaster 80 series muffler. I clamped the inlet on the muffler to the stock I-Pipe, and its really tight, and I wanna take it off so I can raise the tailpipes. I cannot raise them without this tool. Now my question is, will this ebay item:
http://cgi.ebay.com/ebaymotors/ws/eb...065775&r=0&t=0
fit my muffler and restore it, or is it rated too small? Please let me know before the bidding is over, PLEASE! I don't want my muffler melting to my I-pipe before its too late. Thanks
Old Mar 17, 2002 | 08:04 PM
breathment's Avatar
that tool is used to fit inside of the pipe, so if u can't get the muffler off, then you won't be able to fit it inside...
now this is what i did to get mine off. and it will take a while, it probably took me 20 min to get my old SLP muffler off. get a large rubber malet, a torch, and some penetrating lube. spray in the area between the two pipes a coulpe times and let it set for a few minutes. then start banging with the mallet, many many times to loosen up the pipes. if you don't get any where, use the torch and heat up the muffler in pipe, and try rotating\hitting to see if u can get it loose. you might not be able to rotate it until after you get the muffler off.
AND THEN thats when you want the pipe expander to take out the crimp in the pipes. jsut make sure its the same diam. as the pipe u have.
Stroopwafel
Sep 11, 2015 06:38 AM
gta power
Aug 13, 2015 06:15 AM
91rscruiser
Nov 13, 2001 03:20 AM
Z28z
Oct 1, 2001 08:01 PM
