Header Problems???
Old Mar 21, 2002 | 06:09 PM
JR4444's Avatar
Header Problems???
My mechanic said that headers on a third gen is a bad Idea. He said that thr tubes run too close ot the starter, causing it to heat-up and burn out. He said if I installed headers on my car that I'd get really good at changing "burnt up" starters. I have never heard of this is it true??? Thanks
Old Mar 21, 2002 | 07:00 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My headers are pretty close to the starter so I used that heat wrap stuff and it works fine. Absolutely no problems at all. Not getting headers is about the stupidest thing anyone could do if they want to build-up their engine. You'll be a lot faster, all other mods will benifit from them, and you'll even get better gas milage.
Old Mar 21, 2002 | 07:12 PM
JR4444's Avatar
I really need headers with my intake and I just though of maybe getting them Jet-hot coated to cut down on the heat and along with some wrap it should be ok.
Old Mar 21, 2002 | 08:09 PM
robbob's Avatar
If you are worried about starter heat related problems buy a starter heat shield their not that expensive.You could also buy header wrap but I've heard that it is actually not good for the longevity of the headers,personally I think header wrap is ugly.
Old Mar 21, 2002 | 10:42 PM
breathment's Avatar
get headers, and get them coated, you wont have any problems
Old Mar 21, 2002 | 11:10 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Or buy a shorty starter. Couple bucks more expensive but you'll never have a heatsoak problem and you'll have more clearance.
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
