hedman headers instal time
Old Apr 2, 2002 | 11:50 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
me and my friends are thinkign about taking a day off of school to put on my headers, will we be able to do it in a span of 8am to 7 or 8 pm? say 12 hours? I heard u have to lift the driver side motor to put that header in, and have to modify the ac bracket on the passengers side, and make sure the 02 sensor is on the backside of the header instead of the frontside, and the y-pipe was a ho to get on.
Old Apr 2, 2002 | 08:52 PM
Hellraiser's Avatar
Re: hedman headers instal time
You shouldnt have to lift the motor up, IF you can get the car jacked up off the ground far enough. The drivers side header goes in best from underneath... I think hedman said to get the car no less than 36" off the ground.
hellraiser
Old Apr 2, 2002 | 10:01 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I can't really give much advice since my car has no A/C or anything else but here is what I did:
The night before you do it spray all the bolts with PB Blaster or some other kind of penetrating oil. Then spray them again just before you do it. Be sure to remove your spark plugs, It makes it a lot easier to wiggle the headers around.
Passenger side - I had to remove the starter and that hard heater piping that runs along the subframe. It dropped right in.
Driver side - This was the biggest pain. I had to bend some brake lines and ended up scratching my valve covers. I removed the steering shaft (kinda tricky the first time you do it but then its easy) and it wiggled right in. The brake lines are very close to the headers though...
Old Apr 3, 2002 | 12:27 PM
Matt's Avatar
So what are the demensions of the Heddman Headers?
Old Apr 6, 2002 | 11:31 PM
86maro305's Avatar
i dropped the tranny down a little bit and they slide in quite well.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
