WTT: My 24mm Sway Bar for your 21-22mm Sway Bar
Car: 2002 Z28
Have: 24mm 1LE Rear Sway Bar w/ poly bushings and non-stock brackets.
Need: 21-22mm Rear Sway Bar w/ poly or low mileage rubber bushings.
Don't Need: 18mm, 19mm, 20mm, 23mm, 24mm or 25mm or any front bars
I would also like to see some pictures with measurements verifying the size, I can send pictures if requested (on wednesday)
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I think I have a 22 out back on my z. let me find out and I will give you a pm. I am assumming you are creating your own setup for roadracing? Larger diameter in rear is less oversteer right?
cheers!!!
cheers!!!
Car: 2002 Z28
I actually sold my 1990 RS to my younger brother.
I have a 2002 Z28 now and am upgrading to a 35mm solid front bar and apparently the 4th gens dont like a too big of a bar in the rear and a 21-22mm bar is a better match.
Too large of a rear sway bar will make the rear end too happy and fishtail when you power out of corners. On my 3rd gen the 36/24mm combo was GREAT but 4th gens are a whole other story.
Car: 2002 Z28
Also, after doing some research, looks like you might have a 21mm bar which would be great. If you find out that you do and can take some pictures, id be interested in a trade.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You're right Klause83Z28's '83 should have a 21mm rear bar if it's still original.I have a '83 Z28 also and have already upgraded to the hollow 36mm front/24mm rear and it is a great combo with the TDS steering brace.If you don't have any luck finding a 21mm bar send me a PM as I still have the one off mine.
darwinprice
17
10-11-2015 11:51 PM
