Ground Effects
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Ground Effects
Hello, I am looking to buy the ground effects kit for any 3rd gen Camaro (87 to be exact). I am located in the Cleveland area of Ohio and would prefer something close by to cut down shipping cost, but let me know wherever you are if you have something. I know there is a lot of people looking for these, but thought it was worth a try posting on here. Let me know if you have any, thanks.
Re: Ground Effects
Don't forget that you will need to get - or need to make - the rocker panel extensions for each side. These things are spot welded at the factory to the rocker panels and the ground FX need then for support. This extesion is what the rocker panel ground FX screw into !
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Ground Effects
What kind of extension is it? The rocker panels on my car come out far enough to screw the ground effects into, but do you mean extended downward?
Also, is there a rear bumper ground effect or is it just a part of the bumper?
Damon
09-26-2015 04:29 PM
