drivers side firebird formula door
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
need a drivers side door without ground effects and pw pl in the new jersey area ill drive and remove
Car: 87 Z-28
Transmission: Automatic 200 Metric Turbo
Axle/Gears: Strange Axles & 5.14 Gears
Re: drivers side firebird formula door
Is a Camaro door the same as a Firebird ????
I have a drivers side door if it will work.
I'm in So. Plainfield
Thx
Pete
Thx
Pete
i have heard they are the same but im not 100% sure. but you are right in my area, im in edison. ill do some research.. is it clean?
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a door located in toms river, from a 91 formula
and yes a camaro door is the same but it would have to come from a sport coupe or a berlenetta those are the ony 2 model camaros without ground effects any other door you would need to fill the holes in the bottom for the ground effects
im down in toms river quite often. is the formula door off the car already? rust on bottom edge? dents?
Transmission: auto
if a door has rust i dont take it off, so the door has no rust, if i remember correctly there is a small door ding but thats it
hey ted, im interested in checking out the door. pm me with your phone number and address. i might be in your area this weekend.. how much you asking?
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
