[MO] WTB Upper air dam 85-90 TA
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Need the plastic piece that attaches to the bumper and folds up before the radiator.
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: WTB Upper air dam 85-90 TA
i have one on my parts car..you need the little spoiler thing or the plastic cover up to cover the under part of the bumper area have both
Car: 85&95 Trans am
I need the piece that covers the underside of the bumper. How much shipped to 63701?
Engine: 350 crate
this is off of a 83 firebird .it matches up to my 88 so it should be same on yours it is a 2 or 3 peice setup two sides and one center 35 shipped..
Car: 85&95 Trans am
That can't be the right part then. It's a solid piece of plastic. It does not hang down under the car.
Car: 87 GTA
Are you wanting the one that attaches to the bottom tabs on the fascia, curves upward to the upper front panel/top of the rad?
Car: 87 GTA
OK....It's actually 4 pieces.
From the nose that curves up. Attaches to another black plastic piece that continues to the rad top. The 2 side "brackets" for that 2 piece I mentioned.
Can't find my camera, or I'd get pics to show it.
Car: 85&95 Trans am
Here's a pic I found on ebay. It's the top piece. It looks like one solid piece to me. I could be wrong though. My car never had one
Car: 87 GTA
You need the black piece? I was referring to the gray one, which is 4 separate pieces.
Engine: 350 crate
i'll double check in the morn to make sure it matches your pic
Car: 87 GTA
My car was a base Firebird so I've got the under chin stuff with the front air dam but non of the air deflector(grey pieces). I guess all the brackets directly bolt up to mine as well. But to answer your question, I need the entire grey piece or pieces(I guess 4).
Found the entire 4 pieces at the local u pull it yesterday, I was so excited about it. $7.49 out the door. Thanks to all for the replies and helping me figure out exactly what I needed!
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
