[NC] frame help
Old Sep 12, 2011 | 07:22 AM
slowboy's Avatar
Car: 1990 CAMARO RS
Engine: 350 - replaced 305 with 350
Transmission: 5 SPEED
Axle/Gears: STOCK [?]
frame help
need to fix this...anybody able to tell me what/how to do it...I've been told that this will come off drilling out spotwelds...is this correct, and where are all the spotwelds located for this
also...is the parts I need to fix this available for purchase, or would they need to be cut off donor car
Attached Thumbnails frame help-img_0543-small-.jpg   frame help-img_0544-small-.jpg
Old Sep 12, 2011 | 08:53 AM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: frame help
You'd have to cut off a donor car. Good luck on the project.
Old Sep 12, 2011 | 12:23 PM
FASTASSBIRD's Avatar
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
Re: frame help
I got a excellent donor Trans am I can cut or drill it out for you
Old Sep 12, 2011 | 04:44 PM
slowboy's Avatar
Car: 1990 CAMARO RS
Re: frame help
Thanks guys...I think I'm gonna look for Camaro needing motor and transmission...I've heard that cutting and trying to fit back together is a hard thing to do and get it right...my wife's wanting to find a 67-69 Camaro needing motor and trans...have a feeling this would be hard to do too
Old Sep 12, 2011 | 05:09 PM
Re: frame help
not bad if the spot welds are drilled out properly little tougher if cut up, but if you have em cut extra not horrible. 67-69 camaros and firebirds not as hard to find as people seem to think, i pass on lots for less then 5k
Old Sep 12, 2011 | 08:18 PM
slowboy's Avatar
Car: 1990 CAMARO RS
Re: frame help
any suggestions where I can search for 67-69...besides craigslist
Old Sep 12, 2011 | 08:42 PM
Re: frame help
Craigslist is your best bet, try using searchtempest.com and searching within driving distance i always use "camaro project" or "firebird project"
Old Sep 14, 2011 | 08:14 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: frame help
I have from a 90 Iroc the complete front radiator support as a cut out ready to ship
I also have the right inner fender and beam but it is still in the car
And have to cut it out.
Email me at 1988irocz28 at gmail dot com
For photos and price
Dave
Old Sep 14, 2011 | 08:25 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: frame help
hook up a chain to a pole and throw her in reverse repeat as neccesary until it looks like new .....
JK donor car and welder
Old Sep 14, 2011 | 07:33 PM
Re: frame help
hahahaha god I wish tgo had a like button.
Mine is cherry and I will drill out the welds rather then cut it apart
Old Sep 26, 2011 | 12:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: frame help
I have a frame cut of the area you need and am 15 mins outside of winston if you decide to keep the car
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
83RDRACR
Mar 26, 2016 08:13 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
