[OH] Looking for a few things
Old Sep 22, 2012 | 06:54 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I'm looking for some things, that I can think of at the moment, that I need to finish my build.
Fascia filler panel for tbi/carb car. Its the part that covers the hood latch.
Body drain plugs
Fuel and brake line mounting brackets including fuel filter mounting bracket
Fog light adjuster screw and spring
Inner fender deflectors (pending)
sway bar mounts front and rear (pending)
power window tracks (regulators) (with or without motor) and power lock solenoids. Preferably both with pigtails.
Power lock switches with pig tails
Door window filler pieces (black triangles) (pending)
cowl screen
license plate bracket (rear)
cargo cover mounts and brackets if you have them
rear speaker "boxes", the fiberglass pieces that go in to the sail panel. Preferably with speaker mounts (pending)
front rotor shields with hardware, may take spindles complete if 90-92 (pending)
lots of hardware, anyone know where to buy it new as a set? Need fender bolts, ground effects bolts\brackets, interior screws. Just all kinds of stuff.
Let me know what you guys have, I'm in zip code 45042 if you want to give me an out the door price. Thanks!
Old Sep 23, 2012 | 06:29 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Re: Looking for a few things
I'm parting out a complete 92 Camaro if theres anything you can use from it. Located in KY. Pretty sure I have all the following and have a complete set of 91-92 ground effects and rear bumper.
cowl screen
front rotor shields with hardware, may take spindles complete.
Old Sep 24, 2012 | 08:59 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
That helps a lot. Throw a price my way. Your about 2 hours away from me I think, you're just south of Lexington right? I'll let you know later on the ground effects and bumper cover. I have a set, but I need to check condition. Its been a while.
Old Sep 24, 2012 | 03:57 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Old Sep 25, 2012 | 11:37 AM
camaroracer21's Avatar
Car: 1983 Camaro
Engine: 358 SBC
Transmission: TH350
Axle/Gears: 9" Ford 4.56s
I have a license plate bracket if you are still looking. Make me an offer
Old Sep 30, 2012 | 09:30 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
bump for the week, updated original post
Old Oct 2, 2012 | 09:45 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I have the fog light adjuster screw and spring.Do you need 1 or 2 and also do you need the plastic nut?
Old Oct 3, 2012 | 12:06 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
If you need screws, nuts, etc, I have them all! When we tore down 3 of them, we kept everything- bushings, rubber bumpers, etc. Easiest way to get a hold of me is snowmobiler8@juno.com since I don't always make it back on here having 2 toddlers in the house.
Old Oct 3, 2012 | 12:29 PM
oramac91's Avatar
cowl screen
I have or can get all that.Have whole car coming friday.With all the hardwear you need.Thanks Jason
Old Oct 4, 2012 | 11:46 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I only need 1 but may take both. I need both plastic nuts as mine is broken. How much you want for them?
Old Oct 4, 2012 | 11:48 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Originally Posted by oramac91
I have or can get all that.Have whole car coming friday.With all the hardwear you need.Thanks Jason at http://www.facebook.com/ThisWeekInCamaro
Sounds good, I haven't heard back from the guy that I had the pending parts coming from so I may need it all. Work up a price and let me know. I need the body drain plugs and the fuel & brake line mounts with hardware also. Including the fuel filter mount.
Old Oct 5, 2012 | 08:40 AM
my82roc's Avatar
I'd do a pair for 15 shipped
Old Oct 5, 2012 | 07:05 PM
oramac91's Avatar
Give me a price and will go with that.Thanks ,Jsdon
Old Oct 8, 2012 | 04:43 PM
Testa Rossa's Avatar
Car: 1983 Z28 - 1999 Tacoma - 1968 M715
Engine: none - 3.4L - 383ci
Transmission: 5sp T5 - 5sp R150F - 4sp SM465
Axle/Gears: none - 4.10 Toy - 5.88 D60/D70HD
Parting out my 83 Z28.
I have all your power window & lock equipment.
And the cover for the hood latch.
Shoot me an offer and I'll find out what shipping would cost...
(probably have everything else too, but it looks like it's may already be pending.)
Old Oct 14, 2012 | 10:43 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Old Jan 22, 2013 | 01:53 PM
84 Joe's Avatar
Want a title? Post!
Car: 1994 Jeep YJ
Engine: 350 TBI
Axle/Gears: ford 8.8 with 4.10
^ are you still looking for any of these items? I am parting out a 84 TA. may have parts for you.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
