I'm looking for a drivers door ground effect for an 89 RS. I have bought several from ebay that were listed as fitting the right years but still havent found mine. I'm pretty sure mine are stock RS. Any body have one they can measure the height and distance from the door at the top and bottom, then I can buy it!! Even if it has a crack or pulled studs, I can fix anything!!!! Thanks.
Do you happen to have a 91-92 one from the ones you bought off ebay?
Quote:
When you open the door and measure at the back, its 3 inches tall (where it contacts the door) and at the bottom it measures about 1.5 inches out from the door. Hope you have it!!Originally Posted by tri power
i have one still on car what is your measurement. Quote:
I think I do, do you know what they measure? I have a couple of different ones.Originally Posted by TheSumOfOne
Do you happen to have a 91-92 one from the ones you bought off ebay? Quote:
Originally Posted by mongo136
When you open the door and measure at the back, its 3 inches tall (where it contacts the door) and at the bottom it measures about 1.5 inches out from the door. Hope you have it!! Any Luck?
It should be a bit shy of 3.5" with a curve towards the rear for the air duct. Drivers side..
Still Looking.......
I've got the one your looking for you can have both sides for $100 plus shipping obo
You should post pics of the ones you have and the one you are looking for. I have some from a 1990 iroc in my shed.
I think I have a few here as well. If you can post a pic, I'll check and see if we can get you what you need.
Quote:
Heres pictures of what I have, the one I need is somewhere between these. Its for the blue car in the picture. If the pics dont show up, I will try again tomorrow, I'm having probs with my home computer. Thanks for any help!Originally Posted by jer4251
You should post pics of the ones you have and the one you are looking for. I have some from a 1990 iroc in my shed. Quote:
Heres the pics.Originally Posted by beths91camaro
I think I have a few here as well. If you can post a pic, I'll check and see if we can get you what you need. Member
Quote:
The top one looks like an 82-84, and the last ones look like they're part of the 90's euro set. Originally Posted by mongo136
Heres the pics. I have an 89 RS as a daily driver, and I do have the part you need.
Will get pics for you tomorrow.
Bethany
The thin one is from a 82' - 84' Camaro or Firebird and the other two are from a 85' - 90' Firebird in your picture. We do have have the 85' - 90' Camaro Door Piece that you are requesting. They run $20.00 plus shipping and handling.
Thank you,
Thomas
www.houseofcamaro.com
Thank you,
Thomas
