[PA] Passenger T-Top needed
Old Nov 3, 2014 | 02:16 PM
joef2002's Avatar
Hey gang. Though i'm aware you will likely only sell them in pairs (which is fine if necessary) I'm interested in a passenger T-top - latching style. it's for an 88 GTA. If you have one, please send me some close up pics (inside and outside) and price. I'm located in 18330 and would love to pick up locally if I can. But will consider shipping if prices are reasonable. Thank you.
Old Nov 3, 2014 | 02:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Passenger T-Top needed
I've got one, Pass side. It's got a defect, One of the ends is cracked off, but it's a good Top otherwise. From an 86,... has small pin., lock but no key, interior plastic trim is good, all weather-strip is OK, $25 + shipping.
Post your ZIP code for a shipping quote, I can post a couple pics too if needed.
It's the only single I've got...... but I do have other good PAIRS of small pin glass tops.
Edit; Just saw your Zip, If your interested just post back and I'll update this thread ASAP.
Old Nov 3, 2014 | 03:37 PM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
i have them 50 for the set of 2 im located in west orange nj 07052
Old Nov 3, 2014 | 03:50 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Just thought I throw it out there I have 2 pairs for $20pr. Glass is in fair shape will need weatherstripping, no keys, and the latches may need to be rehabbed. Both sets are from an 84 and have the molding around the edges. Located in jackson nj
Old Nov 3, 2014 | 07:55 PM
joef2002's Avatar
Eric - thanks anyway. I would need something in very good condition that doesn't require rehabbing.
973Camaro - responded to you with a followup question in another post. Would love to see some pics.
John - can you post pics of the best set you have and best cost + shipping?
Old Nov 3, 2014 | 10:52 PM
John in RI's Avatar
I've got 2 sets that are real good,.. IMO 1 is slightly better than the other.
Pretty Good:
Better:
Both sets of tops include a Key and all the tops have had thier outer edge sanded down and re-painted flat black. All weather stripping is original and in good condition, none of the interior plastic trim panels are cracked or broken, the handles and locks all work as they should. I did not make any attempts to "re-seal" these tops, simply good factory used with a re-painted outer edge.
As with all used parts they are not perfect; There are minor blems here and there - but nothing significant. ( see pics ) I've also found that it's near impossible to take pictures of minor scratches and scuffs on glass tops. The pictures posted above were taken indoors and outdoors to try and get the best look at them possible.
The shipping estimate for a set of tops to ZIP code 18330 is $38. This is just a best estimate based on size/weight. ( 37 lb 31x26x6" ) I can only get an EXACT quote once they are packed. (estimate should be very close) The factory T-Top bag was not included; I have a couple available in various condition if it's needed.
Feel free to send me a realistic offer if your still interested.
Old Nov 4, 2014 | 08:04 AM
joef2002's Avatar
John PM sent
Old Nov 10, 2014 | 11:35 AM
TKR Performance's Avatar
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
John PM is sent as well
Old Nov 10, 2014 | 08:00 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I have passenger t tops pm me
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
