Custom Billet Alum hubs
Car: 1992 RS
Engine: 406 Stealth Ram
Damn dude, how much did that run ya? Are they stock dimensions? I've wanted to do this for some time for my C5 brake swap. Did you make them in AutoCAD and have them machined?
$500 complete with studs and bearings & races. Studs are 1/2" instead of metric. Hub centric area is thicker than stock and rim will be slightly modified. 1/16" needs to be taken off the center lip of the iroc rim. If you feel inside they have a small lip on them and then open up in diameter inside. I will also have to have a hat machined to fit the larger center hole diameter also. They will be strong and lightweight.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
now if you put it back to the stock lug size, leave the longer hub centric area, but keep that the stock size too, and leave the possiblity of moving the edge where the rotor sits to be moved, and keep the price around $150 or so, and you could probly sell them
the rotor needs to come OUT to fit the thick ZR1 brakes.... it can stay stock for the rest....
Car: 91 Red Sled
Very nice.
Now if you're concerned with unsprung weight might I add a suggestion.... 3 letters, IRS. I'm dipping into the road racing scene myself and one things seems apparently clear... solid rear axles will ruin an otherwise good day of driving. That and stock brakes don't work no matter what pads you use.
If you don't mind me asking, what series are you going to be entering? If it's NASA let me know because I have some questions for you.
Car: 91 Red Sled
Originally posted by cy Z28
why spend all that time and money on IRS when what you really need is seat time.
If I had the money I'd have a c4 vette for road racing but until then I'll stick with the camaro and drag racing.
Anybody here have an option about going to coil overs on a camaro and how they put the whole corner weight onto the strut towers. Isn't that a bad thing? Wouldn't you rather have the springs where they are and is the only added benifit ride height and corner weight balancing?
I think these guys know how to drive- thats me in the 3rd position hanging with a $500,000 Lola T-70 and full race A/C Cobra through some infield corners at Calif Speedway.
JP, this is just an open track play car- setup for everyday street use and an occational track day. I don't ever intend to run it full time racing. I am presently building a '67 Mini Cooper RHD 1275S for VARA racing.
Car: 91 Red Sled
I agree seat-time is best but if you're spending money on parts to go fast on a road course I can only tell you that IRS is nice at high speed bumps.
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Those are nice, I'd like to have a set. But like previously mentioned, I'd want a set to fit ZR1 rotors. IIRC.....Baer uses aluminum hubs like those for their 13" track kit. I assume it is the aluminum equivalent to a cut down 1LE rotor.
school boy
Oct 22, 2015 11:47 AM
Little more then my pocket book cares for though
