brazing brass to aluminum
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How hard is it to braze brass to aluminum? Can you use an alum brazing rod?
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ede,
need to weld a brass hose barb to an alum blower discharge. Gonna see 10-14psi boost. bad idea?
-- Joe
-- Joe
actually i thought about it some more and you can't. you might get a zinc rod to work but not sure of the quality. i'd weld a bung on the aluminum and tap it for a pipe thread and get a barb to fit it.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ede,
Can you braze cast iron, or steel bov flange to alum? If so what would you use for a rod, zinc?
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You cannot braze to aluminium. You need argon gas to tig or mig weld aluminium. Only aluminium can be welded to aluminium.
danger that's not 100% true i've welded steel to aluminum, but there's a trick to it that i'm not telling. great way to win a bet or two.
-- Joe
you can braze Steel/Aluminum and Copper/Aluminum, dont see why you could not do Brass/Aluminum... just make sure you get both metals hot enough. Or just Silver Solder it...
lee you can't braze to aluminum. only reason i can think of is the melting point of aluminum is below that of brass/bronze. ok another reason i can think of is bronze or silver solder wouldn't stick to aluminum.
These things run at 350psi+ and dont leak.
And you dont need to melt the brass, you only need to have the metal hot enough to melt the filler. Hell, Copper filler will probably braze Brass/Alum, its a pretty good all around filler.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I know you can braze aluminum to aluminum. I have rods and detailed instructions on how to do it. Heat both parts to 1080f, and then apply the rod.
The issue is I have an alum BOV, but the flange for some reason is steel. I can prolly make a new flange out of alum, but we're talking all day at the machine shop vs welding..
lee if you're brazing you have to melt the brass. how else is the brass going to go anywhere?
edit:
ok i guess i was using a bit of slang defination for brazing thinking it had to be dome with a brass rod. after looking in the aws terms book they classify several things as brazing not using a brass rod.
edit:
edit:
edit:
A brazing rod normally has a lower melting point than the base metal, or else your whole project would start melting away.
Royal_Z
Sep 30, 2015 08:45 PM
