Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
New Intake
Old Mar 13, 2004 | 10:22 PM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
New Intake
I want to modify my intake so that the clean box is getting air forced into better than it is right now. the set up right now is pretty weak and i think that i can get a little more hp by increaseing the air flow. so what i thought of doing is extending the air box/tubes so that they scoop air from under the car. anyone done this before or think it is possible to do myself? otherwise do you know of any kits that are realtively cheap that can be used to set up my intake like this. i figure the cheapest way to gain some hp is to fix that crappy intake system on my firebird. thank
Old Mar 13, 2004 | 10:41 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
seen it done with pcv on imports. get a cowl hood.or take out a pair of your headlights and put it in there
Old Mar 14, 2004 | 12:14 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
There is a tech article about how to do this somewhere on this site. Do a search.
Old Mar 15, 2004 | 11:26 AM
FastBack's Avatar
Knyghtmare, could you get me some info on that thridgen rally you were talking about haveing in wisconsin. i sent you a pm but never got a reply. if you could get me some info on that, that would be awesome. sounds like a good idea. thanks
Old Mar 19, 2004 | 02:37 PM
UncleSam89's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
does pvc pipe really work for intake? can u use it to run the intake to the back of the grill to get more and cooler air or would that do anything at all
Old Mar 28, 2004 | 10:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yep. They are pretty easy to make, so alot of cars have them. On 3rdgens they are usually routed to either above the battery, or the same place on the opposite side of the car.
Old Mar 29, 2004 | 08:49 AM
Mathius's Avatar
https://www.thirdgen.org/newdesign/tech/ramair.shtml
Old Mar 29, 2004 | 10:42 PM
jonarotz's Avatar
Car: 91 Z28
Just curious but would the ram air ducts block your airflow through the radiator?
That is the only place outside air is routed through to the radiator.
Old Apr 5, 2004 | 10:07 PM
FastBack's Avatar
Mathius, isn't that only good of the camaro intake setup? my intake just runs to the passenger side of the engine bay and sits in the cleaner box. there is no split in the intake hoseing. or is that what is being fabricated? thanks
Old Apr 6, 2004 | 05:32 AM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
No, they are different, there's no split on Firebirds, and that is not being fabricated here.
Here's an idea for a ramair scoop system I am planning on making myself:
http://www.geocities.com/91formula/ramair.html
I'm gonna route the output from the scoop into the intake of the standard airbox on the firebird.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
