Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Kmember Tube LCA's Rack and pinion
Old Mar 15, 2004 | 08:05 PM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
Transmission: five speed
While I have the front of this thing all torn apart, How much weight will I save/strength will I gain by going to a Tube K-member and Control arms?
The peices I'm looking at come either with or without coil spring pads, I assume for optional coil-over struts. Does anyone make coilover struts for third gens?
Has anyone ever converted to rack and pinion? Advice? tips and tricks?
Thanks guys. When the car is ready to race, I'll put
www.thirdgen.org across the back of the spoiler. (with the boards permission, of course)
Old Mar 16, 2004 | 05:25 AM
ede's Avatar
ede
170 pounds i think is what i read
Old Mar 30, 2004 | 10:52 AM
Intensity_Z's Avatar
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
BMR's is said to drop 60 lbs from the k-member and i think 10 lbs a pop for the arms.... so around 80 lbs which is a ton
Old Mar 30, 2004 | 11:23 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
It'll be REAL difficult to drop 60 pounds with just a k-member swap, being that the stock K-member itself weighs about 45 to 50 pounds The stock A-arms are giants though, they weigh about 18-20 pounds each IIRC. Dropping the spring pocket in the K-Member and A-arm on a tubular setup would save a considerable amount of weight though.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
gord327
Sep 29, 2015 10:18 PM
