Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
cheap home-made mods that shaved .3 seconds in the 1/4
Old Mar 16, 2004 | 11:38 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
check page 2 on my site. I have time slips to verify all stats.
Old Mar 17, 2004 | 01:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
.3 by homemade ram air, smog pump delete and a battery in the back ???
so you dropped from 13.8 to 13.5...???
did you 60' change as well? i'm guessing the added traction by the battery in back is what helped your times out the most
Old Mar 17, 2004 | 01:35 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I picked up a total of 3 tenths by unplugging the alternator, and lock up converter switch.
Old Mar 17, 2004 | 01:53 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Just unplug the alternator before i race??? Does this make it spin easier?
as for .3 tenths it was when my car was in the low 14's a few years ago. I when from consistant 14.40's to consistant 14.10's.
It was on the same track 2 weeks apart in similar weather conditions. I was pulling 2.10's in the 60 ft mark. the times were the same . the battery relocate i just did.
That was before i invested in a g-tech, i do runs now on the same day on the same road, and average a few runs to be more precise.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
TheTraut88
Sep 7, 2015 05:22 PM
Stryker412
Sep 7, 2015 09:11 AM
L0tuS
Sep 4, 2015 11:16 PM
