Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
wonder bar info please
Old Jan 29, 2004 | 05:50 PM
kevin arnold's Avatar
Car: 1987 ta
Engine: 355
Transmission: t 5
hi. has any one made there own wonder bar. if so i would like to get deminsions{my car is covered in snow} to make my own. also has any one boxed in their rear control arms, and if it is worth the work. thanks kevin
Old Jan 29, 2004 | 10:09 PM
MCas7's Avatar
In my opinion, wonder bars are cheap enough to buy. You should check out Top Down Solutions, they are a site sponsor at the top of the page. I bought mine from them and it is very good quality and very good price. As far as the control arms go, unless you really want to box your factory ones, they are also pretty cheap to buy in the aftermarket. I bought mine from Spohn, just the regular ones, not the adjustable ones or anything, and they are great as well. Just my opinion.
Old Jan 30, 2004 | 12:11 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I agree with the TDS bar. Very nice peice. Can't wait to install mine. Boxing the factory LCA's is cake. Just be sure to replace the bushings in them. Just by boxing my LCA's and adding a poly torque arm mount made my car launch much harder.
Old Jan 30, 2004 | 07:22 AM
ede's Avatar
ede
if i were to make a wonder bar i'd get the snow off my car and measure it, nothing like having the dimension of the actual location the part will go in. as for boxing the rear LCAs it isn't much work at all, damn near no effort at all so yes i'd think it was worth it.
Old Jan 30, 2004 | 12:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I made a wonderbar for my car... the dimentions were 28.5" long (bolt center to bolt center) and 3.5" between bolts (center to center) on each flange.
Yours may vary a little... every car is a little different.
Old Jan 30, 2004 | 05:35 PM
Car: 1987 ta
Engine: 355
Transmission: t 5
hey air adam thanks for the info . have a nice day kevin
Old Jan 31, 2004 | 02:27 AM
j'sirocz's Avatar
Car: 86 iroc z
Engine: 305 carbed
Transmission: 5 speed
wonder bar
hello. id have to say they are cheap enough to buy as well, i have a spohn performance adjustable one on my i roc and it was only 95 bucks, a non adjustable is only 60 from them, very cheap but very noticable improvement.
Old Feb 13, 2004 | 01:20 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i made my own....took me about 2 hours to do the hole thing.
its made from heavy 1/8 wall 1" square tubing with 3/16" flanges.....fits mint.
Car: '91 Camaro RS
another
Old Feb 13, 2004 | 03:12 PM
Air_Adam's Avatar
Good job... looks way better than mine, lol
I think the way I made mine, its too weak to do much good, so I just bought a factory one for $5
Old Mar 13, 2004 | 10:18 PM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
just buy one, its prolly just as cheap to find one online. before you get one of TDS check out ebay motors. you can usually find one there even cheaper.
Old Mar 13, 2004 | 10:43 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
anyone have pics of them installed in their car
Old Mar 14, 2004 | 01:31 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
https://www.thirdgen.org/techbb2/sho...hreadid=221912
Old Mar 14, 2004 | 08:02 PM
jocww's Avatar
so what does it do exactly
Old Mar 17, 2004 | 06:54 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
its like a STB for the bottom. links the frame togeather causing less stress around the steering box and crisper cornering/steering. if youve ever seen pictures of a cracked steering box area, youll want to buy one after looking
wow i liked the boxed one. i have boxed subs and arms. wish they sold boxed braces. i want everything on my car boxed. hell, if they had boxed sway bars id buy em trying to keep my suspension totally BMR though
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
