Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Anyone ever use block plates?
Old Mar 19, 2004 | 06:04 PM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
Transmission: five speed
Am Considering using block plates to mount my engine? anyone ever done this? how'd it turn out? Did it open up enuff room for a decent set of tri-y headers?
Old Mar 20, 2004 | 11:45 AM
bottlefed89's Avatar
I had a motor plate in my 92 but it had a 12 point cage to attach the front motor plate. I am sure you could make something off the front uni body frame and strut tower to mount it.
it did clear up lots of room for my custom BB headers
Old Mar 20, 2004 | 02:35 PM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
I will be running a cage as well. Did the mid plateTake the place of the block plate from lakewood? or was it used as well?
While I have all of this torn apart, is it worth anything to move the engine, up,down, back forward?
Should I leave it in the factory position?
I've read some of your posts before, and you seem pretty knowledgable. Look for a more detailed post about my chassis, I'd like your input.
Old Mar 20, 2004 | 04:10 PM
I used an aluminum front motor plate and a 1/8" steel mid plate from S&W racecars, we cut the firewall and moved it back to set the motor back 3 inches and up 1. then we had to cut the tunnel out and have a removeable aluminum tunnel installed. plus make a solid trans mount. all in all it was alot of work but well worth it when we scaled the car. I wish I had the printout of the actual readings but they went with car when I sold it. but it definently moved atleast a hundred pounds to the rear tires.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Kenwood
Sep 11, 2015 12:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
