TBI Strut Tower Brace?
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
Anyone have any pics of a STB on a TBI car? I want to build one, but can't think of a great design. I can build anything, but I need a starting point. Thanks
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
that's the best i could do for ya buddy.it's a MAC stb.TGO thread
Car: 88 sc. convert
Engine: 305 TBI
That looks pretty good. I think I can build a pretty sweet one cheaper than $100. I have to wait until my motor is back in of course. Thanks guys.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I've got a few pics up of the one I made.. it gets me by for the $10 I spent on it. http://www.geocities.com/tzfbird/STBp.html
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by carlover01
shifty's car lol
shifty's car lol
Originally posted by Ions91Z28
I'm curious of shots on how it mounts up to the firewall as well, seems like it'd be a bit weak.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
..i saw this post then went to work and hour later out of a scrap peice of 4foot 1 inch tubing and two 5inch by 2 inch peices of flat stock i had a strut brace. all i did was measure the width cut the flat stock drilled holes for it,tacked a mig weld took it off welded it and was done.. except mine runs straight across the intake no bends nothing even goes under the air filter and clears it by 1/2 inch. solid as hell and works like a dream. all in the same day i put my wonder bar on. what a difference in stiffening this 12 year old car up.
thx guys
thx guys
Car: '90 RS
Engine: 377 LSX
Originally posted by iansane
Does anyone have any idea if something like that edlebrock STB might fit around a stealth ram?
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The HSR barely clears the stock hood from what I've seen. There's really no room for a STB above it, and you can't go around the front like a carb because the TB and intake plumbing is in the way.
Car: '91 TA vert
Engine: turboLSx
Not exactly. The HSR is set up just like a dual-quad tunnel ram, but with a TB on the front instead of 2 carbs on top. The runners are big, and take up almost all the space below the plenum. There's really no room at all between them.
It may be possible to run one under the TB, above the serpentine accessories, but it would be a VERY tight fit if it worked at all. You'd have better odds going over the top and praying the hood will shut.
Car: '91 TA vert
Engine: turboLSx
Looking at my engine the way it sits right now, there is at least 2.5" between the upper plenum and the manifold. There is NO room under the TB though. The space between the front and rear posts or whatever is quite far back, so the STB would have to angle down and back. My thoughts are would it even be a benefit with it bent that way? Would the engine torquing back and forth during hard driving make it hit anything under there?
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
well your gonna want the strongest way .. if im thinking what your r i dont recomend to many bends kinda defeats the purpose i guess. but i would take a look at after market ones if i was you and go from there with your plans.
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
does anyone have specs on the stock and pipe sizes used on the mac or edelbrock setup i can get 24'lengths of steel pretty cheap was thinking about buying a length or two and making a wonder bar also
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
its very easy to make a wonderbar theres actualy a feew post on here about making them. i just bought one tho because there so cheap. do a quik search for wonder bar.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
materials and tools i used:
sawsall
4foot of 1inch pipe cut ends to apropriate angle
flat stock mines 1/4 inch thick measure 2 w x 5 L
drill
bolts
mig welder
and an hour of your time.
you might have to bend the steel to meet your needs or make brackets to lift the steel up over your intake setup whatever it maybee.
Car: 87 Firebird Formula
Engine: 305 LG4
Is a backing plate needed on the strut towers?
Or would washers be sufficient.
I think I've got all the stock I need for this. Might weld some up over the weekend.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Yep, talls are no problem with the Edelbrock..and niether are big blocks, take a look at these pictures
https://www.thirdgen.org/techbb2/sho...5&pagenumber=2
Car: '90 RS
Engine: 377 LSX
Originally posted by Nate's 88
as far as what Shifty said about the 4th gens and the firewall being weaker, if im not mistaken a triangular STB can actually crack the front windshield of a 4th gen.
There is no backing plate for the strut mounts. You drill the holes and simple put a nut on the end of the bolt once you feed it through the hole. There is a backing plate on the firewall lip though.
