Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
corvette IRS
Old Apr 11, 2004 | 07:38 PM
mjmotorsports's Avatar
Car: 1985 TA
Engine: TPI 383 stroker
Transmission: TH700R4
corvette IRS
has anyone ever converted the solid rear axle to a late model (85-up) corvette independent rear suspension? im sure some sort of rear subframe would have to be fabricated. i have a rear end out of a '97 Corvette
Old Apr 11, 2004 | 09:41 PM
onebinky's Avatar
If you try doing a search, I think there is a member who has done this before. I stumbled on the post when looking for something else. It seems that it can be done, but I couldn't give you the details on it
Old Apr 13, 2004 | 10:00 PM
trigger GTA's Avatar
Car: 92 TA vert
this guy did it but has no email links to ask questions. it does has a good set of pics to look at
http://www.quarter-mile.net/IROC_index.htm
Old Apr 26, 2004 | 03:08 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Why would you want to if youre running any kind of power? Those rears suck.
Old Apr 26, 2004 | 03:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
run a Dana44 pumpkin (or any other center you want)
then use the suspension/chassis pieces
very strong, good hooking IRS rear.
the IRS itself isnt a bad design.. its just that most IRS cars are powerless from the factory, so the rears are kinda weak.
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
