Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
AutoMeter Custom Gauges Need a little help
Old Jun 10, 2004 | 05:07 PM
FastKitteN's Avatar
Car: 1988 Camaro
Engine: 5.7liter v8 (LT1 carb)
Transmission: th-350 rebuilt with a 2400-2800 stall
I took the stock black piece and made the holes larger to put my speedo, tac, volts, and fuel level in. I am doing a motor swap and I am using all aftermarket gauges. Anyone done this and made turn signal lights and warning lights still work? And how hard it to hook all this stuff up? The engine is a lt1 carbed. Transmission is a th-350. Any info would be helpful.. thanks
Old Jun 11, 2004 | 12:10 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
what warning lights with a carb? besides the brake light you mean?
anyways i just bought a thin piece of sheet aluminum from home depot and drilled out the holes for the guages. then i bought some 1/2inch lights from radio shack for the turn signals and the brights. basically there's a light green and dark green wire for the turn signals i think(might be blue, have to check schematics) and then a green or blue wire for the bright signal. Other than that it's easy to wire up. schematics can be found online easily enough.
Old Jun 11, 2004 | 01:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Like xpndbl3 says, you can wire up bulbs to replace the turn signal, brake , choke and idiot lights without too much difficulty.
When you get a fuel gauge, try to get one that works with the factory GM sender in the tank, it'll be a lot easier than replacing the sender.
As long as you're making your own panel, you could replace the idiot lights with gauges while you're at it. Just replace the factory coolant temperature and oil pressure switches with senders for the gauges and use the existing wiring.
Old Jun 11, 2004 | 07:15 AM
FastKitteN's Avatar
Car: 1988 Camaro
Yeah I have all Phantom autometer gauges
speedo, tac, fuel level, volts, already been hooked up in the water temperature and oil pressure. thinking about getting a transmission temp also. We just werent sure since I took that white piece out my husband said something about without that piece the lights would be able to make contact.. I dunno tho
Old Jun 11, 2004 | 08:29 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
When I still had the 3rd gen dash installed I had a custom dash for these gauges in there, but after installing the 4th gen stuff I had to rdo it again. Very simple and easy to do. I plan on redoing this one again once the drivetrain is finished since I wanted carbon fiber behind the gauges but the wait really ate into the cars schedule for the racing season so I had to make do.
This is an old pic when under construction but I think you can make out the little lights like your referring too.
Attached Thumbnails AutoMeter Custom Gauges Need a little help-car-pics-005.jpg
Old Jun 14, 2004 | 01:01 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Way to use those 4thgen vent holes! I always hated their location, clean setup too
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86IROC112
Sep 11, 2015 04:04 PM
90formulaVortec
Sep 8, 2015 12:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
