Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cowl Induction
Old Jun 22, 2004 | 10:49 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Cowl Induction
I have a three inch cowl hood (with functional holes in the back) on my 87 IROC. Carburated. Anyone have any ideas/pics to make this a fully functional cowl induction setup? Thanx
Old Jun 22, 2004 | 11:04 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
get a rubber seal that goes on top of your air filter. but a cowl only draws cool air in it doesnt mean that is has to go to ur carb that would be ram air. is that what you want to do. if it is then use the rubber seal method. otherwise it is functional
Old Jun 23, 2004 | 07:25 AM
AFTERMIDNIGHT's Avatar
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
it not the greatest pic, but it will give you a ballpark idea...
Old Jun 26, 2004 | 04:53 PM
TwinTurboROC's Avatar
what i wouldnt givve for one of thosee old tube chassis 3rd gen f body frame... the old chassis
Old Jun 27, 2004 | 05:35 AM
vampiroc's Avatar
Car: Z28
Some first gens had functional cowl induction. IIRC I think that there was a flap that would open as you increased speed allowing air to flow in when necessary.
Old Jun 27, 2004 | 06:27 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
twenty bucks and a few hr`s of work
Old Jun 27, 2004 | 06:29 AM
Old Jun 27, 2004 | 06:40 AM
hood
Old Jun 27, 2004 | 12:56 PM
NEEDforSPEED's Avatar
still building mine..........
but i used a hood seal around the aircleaner... then im going to take a sheet of
alumanum to use on top of the 3" harwood hood i have......
and cut out a hole
Old Jul 14, 2004 | 10:55 PM
2camaros1kid's Avatar
Car: 89 camaro RS and 90 camaro IROC Z
Engine: 2.8MPFI V-6 and 350TPI 5.7 liter V
i was thinkin of making my stock iroc hood and the recessed place where the vent things go and making ti into small cowl inductions. i think it would look cool and it may not put a lot of air in but it would let some heat out!
Old Jul 14, 2004 | 11:19 PM
jocww's Avatar
do u use weather stripping to seal it mine is just a copy of a goza type pan
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
aharvel50
Sep 21, 2015 07:31 PM
