Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
What Welder
Old Jul 19, 2004 | 04:49 PM
Dan W's Avatar
What Welder
I'm looking for a TIG welder that will work for doing 16 gauge stainless headers to 1/4" thick flanges. It also needs to be able to handle 1/4" thick aluminum. I'd like a machine that is 50 and 60 hz capable.
Any suggestions? What do you think about the Miller Maztar 200?
Old Jul 19, 2004 | 11:51 PM
biggtime's Avatar
You probably should have put this in the fab section.
But I use a Miller synchrowave. To weld 1/4 aluminum you are going to need at least 250 amps or you will have to preheat the aluminum
Old Jul 21, 2004 | 07:03 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I'm happy with my Lincoln Square Wave 175. Seriously, any TIG will work out fine. Lincoln, Miller, Hobart (i.e. Miller), etc... Even the home built Briggs & Stratton w/ alternator TIG. If you don't mind spending $2k+, the new solid state boxes are awesome. Very adjustable, they work on 110/220V, and only weigh about 35 lbs instead of 200 lbs. I have welded 1/4 aluminum w/ the 175, maxed out. If your butt welding it, you'll need to do several passes. Fillet welds, I would still bevel the edge. Stainless you need much less heat.
Old Jul 21, 2004 | 08:12 AM
ede's Avatar
ede
for anything except aluminum or any white metal i'd run tig off a stick machine and forget all the extra expense and parts of a dedicated tig outfit. however since you want to weld aluminum too i'd look at what miller has to sell and i'd look at 300-350 amp machines. i have a 250 amp and seldom weld aluminum but when i do it isn't near big enough
mrdevontay
Sep 2, 2015 08:04 PM
TBIformula91
Oct 3, 2002 09:59 PM
Jester
May 10, 2002 08:52 AM
silentneko
Mar 10, 2002 12:17 AM
Rob90TA
May 30, 2001 04:12 AM
