Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
86 plenum to 91 SD?
Old Aug 22, 2004 | 08:32 PM
AC's Avatar
AC
Car: Used to drive a camaro
86 plenum to 91 SD?
I bought a 86 upper plenum and was told there are differences between the 86 and a 91 speed density upper plenum. I'm planning on using this 86 in my SD setup for my 383. Do I need to machine any vacuum ports or drill any holes? Specifically behind the throttle body area?
Old Aug 23, 2004 | 08:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
no, I used my 88 setup when I switched to speed density. I personally added a third vac port for the map sensor (just in front of the original two. (not required but, I felt better knowing it had it's own port)
the only time switching pleniums gives any problems is when using the 90-92 on a maf setup (sets off the ses light)
Old Aug 26, 2004 | 10:45 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You want the MAP to have it's own vacuum port from the manifold if at all possible. I had a friend with a swapped MAF system converted to SD and it ran much better after I drilled/tapped a hole in the plenum for the vacuum feed. Before he had just T-ed a fitting running from the TB and it stumbled a bit at idle and just off idle at tip in...
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
