so has anyone here ever made a monoblade throttle?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im thinking about making one out of a extra one i have hanging around.. basicly just cut out everything in the middle.. smooth it all out (epoxy/techno weld if needed) and cut a new large oval throttlebody....
has anyone here done that?
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
there's a dude on http://nkyfba.homeip.net/nkyfba/index.php? that goes by the screen name NOMAD that does just that.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: so has anyone here ever made a monoblade throttle?
Engine: 4++,350 & 305 CIs
I made my own in 2 days ( with a extra trottle body) took it apart and dropped it off at a machine shop, told them to bore it to twin 52 mm and cut the center out ....I made my own blade out of sheet aluminum stock with a hacksaw and a hand file...I had to make a few to get the hang of it
I also had to file the center of the shaft flat ....
I picked up some epoxy from a parts store and filled in the holes then sanded it smooth.. i put the t-body back together bolted it on my car set the tps then drove home from work (45 mins) its been on since 92
I also had to file the center of the shaft flat ....I picked up some epoxy from a parts store and filled in the holes then sanded it smooth.. i put the t-body back together bolted it on my car set the tps then drove home from work (45 mins) its been on since 92
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
did you have to mod your intake manifold for this or did you just buy an aftermarket one? not moding the intake manifold would just make it a waste of time am i right?
Jerry
Terrell351
Jun 13, 2021 01:13 PM
