Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Any ideas?
Old Sep 25, 2004 | 11:53 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Any ideas?
Anyone have any ideas of how I can rig up a motor to my liscense plate so all I have to do is push a button or flip a switch, and the liscense plate will fold down? (Just for showing off and intimidating, nothing illegal).
Old Sep 26, 2004 | 12:45 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hell if i was gonna do that id make damn sure id do it for illegal purposes too. id use an actuator or even a cable would do it but that takes physical work. im sure u could prob use a small motor from like a rc car or something
Old Sep 26, 2004 | 12:52 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
posting things like id make sure id do something illeagal with it is a good way to get this thread locked please dont post things like that......
if your just wanting it to fold down .....then run a cable to it thru the car and attach it under the dash like the brake and hood latch are then take the factory springs off the liscense plate bracket and switch them around to make them push it down instead of pull it up and fabricate a latch to hold it up when you push it up and then all you have to do is pull the cable and it will unlatch and open up pop...just like a hood
or you could get a window motor and mount a pulley onto it and do the same thing with the springs and run a cable from the pulley to the plate thru the trunk this will require drilling a hole for the cable and attach it and run some wires to it for power and install a third window switch in the console for it then when you want to lower it just hit down and let the springs pull it down as the cable loosens up and when you want to go up just hit up and wind it in ......should work just have to figure out how to mount the window motor in the trunk where it isnt really visable ......hows that sound??
hope this helps ya ....
Old Sep 26, 2004 | 03:11 AM
Rage13's Avatar
Car: 89 Firebird
check out your local hobby shop and look around the remote control car/boat/plane section for some servos.
Old Sep 26, 2004 | 08:37 AM
92RS3.1L's Avatar
Car: 91 Z28
Hey guys, thanks for the response.
Old Sep 26, 2004 | 08:19 PM
Mathius's Avatar
Rig up a bracket and use a linear actuator to operate it so it slides down from under your bumper cover or something I've seen it done on pickups, and now they even sell kits for it.
And it's not illegal to want to hide your license plate at shows to impress the judges on your clean body lines, so they do have info on this if you look around. Like I said, I think it's StylinConcepts that has a kit now for trucks.
Mathius
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
