Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
T-5 To Auto
Old Oct 10, 2004 | 09:25 PM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
T-5 To Auto
Let see some of your tunnel fabrications pics for the big hole in the tunnel on a manual car then going with the auto trans i need some ideas thanks.
Old Oct 11, 2004 | 11:19 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
why do u want an auto manual all the way baby
Old Oct 12, 2004 | 12:02 AM
1320 Right Ln.'s Avatar
I just recently went throught that exact swap in my 92 camaro, but sorry i don't have pics... and i'm too lazy to tear apart the center console again.
but, i remember what we had to do. The stupid thing with the unibody design of these cars, is that the center "hump" is completely different in manual and auto cars. we had to cut out the floor of my old 89 IROC. Just the section, just in front of that bracket that the center console bolts to. I forget the dimensions of the piece we cut, but it wasn't all that big. As a template, you can use the thick rubber shifter boot that's bolted to the 5-speed floorpan; that's what we used as the final trimming template. Then we bolted onto the 92's floor pan, sealing it up with silicone. If your using the stock shifter, you might have to also take the mounting brackets from an auto car... i have the megashifter, which uses a different front mount.
cutting out the old floor pan was a PITA thought, cuz first you gotta drill out all the spot welds.
Old Oct 12, 2004 | 01:57 PM
TexasLT1's Avatar
Car: '92 RS
great technical response
Old Oct 13, 2004 | 06:08 PM
ljnowell's Avatar
Perhaps he prefers an auto for racing, as many many people do. Thats not the point though.
Old Oct 17, 2004 | 06:20 AM
rustbird's Avatar
Car: 92 firebird
You da man thanks!
Old Oct 17, 2004 | 06:21 AM
rustbird's Avatar
Car: 92 firebird
Yeah they are pretty cool when they explode! heh
Old Oct 17, 2004 | 06:22 AM
rustbird's Avatar
Car: 92 firebird
Right on the money brotha
Old Oct 17, 2004 | 06:15 PM
i hope this doesn't come too late, but I took some pics of the cut-out floor from my old IROC that's still sitting in the driveway. Like I said, i'm 2 lazy to take apart the 92 tho
you can see the cut-out part and stock shifter lock cable. that thin plate of metal is all there is to the trans/driveshaft tunnel. After seening this, I wouldn't reccomend that Jegster Torque arm to anyone.
Old Oct 18, 2004 | 12:25 AM
jocww's Avatar
yea but manual means you wont have to buy ballon type converters for nitrous or trans brake or new clutches and bands
Old Oct 18, 2004 | 12:49 AM
rustbird's Avatar
Car: 92 firebird
Does it flex at all?I was thinking the same thing but put it on top from the inside Put temp spot welds in just to hold it then then cut all the access from the side and finnally weld it in.
Ill let you guys know how it goes prolly try to get it all done by sun.
Old Oct 18, 2004 | 01:54 AM
it doesn't flex at all. well at least not any more than it normally would from the factory. we only cut out the floor from the old car, but the 92 wasn't cut at all, we simply laid the auto floor section on top of the manual, and bolted it into place using the same mounting locations used for the manual boot. this area didn't need to be welded in our application because nothing really puts any weight on it. The shifter mounts to the factory mounting point in the back, and the front one mounts in ahead of the cut out section.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
