Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Hi frequency start (welder question)
Old Oct 16, 2004 | 10:26 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I just bought a Miller Syncrowave 250 and finally had the electrical put in today (240 volts and 100 amp breaker ). On a clean piece of steel with a freshly "penciled" piece of 2% tungsten I'm having a problem getting the arc started without touching the piece. If I shut off the hi frequency start I can weld a bead just fine. I adjusted the hi freq gaps on the welder (.011" as the manual says) and still don't get any hi frequency start. Is there anything else I should be looking at?
Old Oct 17, 2004 | 01:26 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Nevermind. I just learned how important the gap is. I set it to .009 and it works fine now.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
