Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
My late night quest for 2,800 pounds......
Old Jul 5, 2009 | 01:46 PM
  #401
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Re: My late night quest for 2,800 pounds......
Originally Posted by tsfso59
In the process of a 1982 Z-28 race car only. I contacted a reputable chassis builder about weight in a 3rd. Gen and this is what he had to say, and I quote:
The lightest Camaro we ever built for SS/GT was a small block car. It
weighed 2625 wet and ready to run. Most are in the 2650/2675 range. It
takes a lot of work to get them that light.
NHRA Super Stock class is basically a back half only type of class. All the stock interior and street equipment still has to be in the car. The motor and transmission has to be stock type and equipped for the year of manufacturer. No fiberglass or lexan, unless origionally equipped.
With a motor change and clear title, these cars can be driven on the street again..I've seen it
Yeah getting old SS cars back onto the street because they aren't as competitive or because the owner wanted to move up to the next new body style seems to be part of the roots of what prostreet is all about.
Old Jul 10, 2009 | 05:05 AM
  #402
to0kold's Avatar
Car: 1983 camaro w Air Ride
Engine: tuned 355 sbc
Transmission: Bulletproof 700r4
tubular A-Arms would shave a decent amount of weight off
Old Jul 11, 2009 | 09:47 AM
  #403
zlathim's Avatar
Our street stock (1984 SC) scaled at a trim 2650# wet with no driver.
https://www.thirdgen.org/forums/fabr...ro-street.html
Old Jul 11, 2009 | 10:23 AM
  #404
the_am_man's Avatar
Car: 82' T/A
Engine: LG4
Transmission: THM200c
I didnt see anyone mention the fact that if you use a early 3 speed auto (th200c)
in your car you can save alot of weight. The th200c only weighs 1 lb less than an aluminum powerglide (96lbs) , also lower rotating mass than a th350/700r4 (700r4 weighs in a 140lbs)
check this thread out...
http://www.turbobuick.com/forums/tra...ag-racing.html
Old Jul 11, 2009 | 08:03 PM
  #405
tsfso59's Avatar
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
I weighed my doors last night and those tanks weigh 96 pounds a piece...that is a ton of weight. I now the street guys need to have all the protection they can get, but I'm not one of them. My 82' is a race only car. Not wanting to spend $620 on a set of fiberglass doors, I am in the process of trimming as much weight as I can off these tanks...one door is almost done and I bet they will be 50 pounds lighter...each door....
Old Jul 30, 2009 | 05:08 AM
  #406
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
"I'de say the doors weigh 90 pounds each, they're ridiculously heavy!"
this was a direct quote I made a while back, I was told they weigh "65 pounds" I'm glad my weight lifting judgement hasn't failed me over time LOL.
Old Aug 4, 2009 | 01:38 PM
  #407
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i know this tread is old, but good weight reduction on the front end could come out of a tubular k member, tubular control arms. tube torque arm as well, and even a crossmember.
Old Aug 4, 2009 | 03:47 PM
  #408
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
a-arms are not that heavy stock, and tubular ones aren't meant to be lighter.
just cleaner.
unless you switch to a coil-over setup you wont save much weight with arms alone
if you do arms with no spring perches, k-member with no spring perches, and get coil-overs you could save a good amount of weight
Old Aug 14, 2009 | 07:34 AM
  #409
This is very true, I put a full tubular front end under my car and didn't shed much weight. Most of the weight to be saved form this setup is in a coilover/rack setup and you give up ALOT with the swap.
Old Aug 17, 2009 | 08:35 AM
  #410
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
what did you give up?
Old Aug 17, 2009 | 01:11 PM
  #411
Ride, turning radius, I now need to reinforce the strut towers, had to spend a fortune getting a newly designed setup put in because my old setup blew a strut mount into the hood, it's more hassle than it's worth trust me. I kept all my factory parts and have considered putting it back stock more than once. The worst part was when I picked up the factory K member and A arms with one hand and thought "wow that weighs about the same as the tubular stuff". The heaviest part was the steering box, I could've just threw a manual box in and called it a day. Hopefully if I keep the tubular stuff it'll pay off if I do a turbo setup.
Old Aug 17, 2009 | 01:32 PM
  #412
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Can you post a pic of your setup? I can't imagine how the ride and turning radius would be affected.
Old Aug 17, 2009 | 02:50 PM
  #413
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
youre in a weight reduction thread, so im going to assume you did these mods for drag racing.
i run a spohn strut mount with my coilovers and my car actually rides better now that i have coilovers on the front. stock strut mounts are a big NO as they are rubber with hardly any reinforcement.
turning radius will suffer with a rack and pinion setup unless you use an aftermarket spindle or modify the factory one. i modified my factory spindle to work with a rack setup and it turns better than the s10 box ever did.
a tubular k member will save you a good bit of weight over the stocker. i dont remember exact weights, but i want to say all of the stock k member setup was close to 50 pounds and my PA unit was only 19. thats a ton of savings to me.
its post like the above that will turn people away from lightening a car.
there are downsides to everything, but if you are looking to remove weight and gain space, i dont see how you can go wrong.
Old Aug 17, 2009 | 03:36 PM
  #414
My car is at "PA Racing" or what that used to be right now getting a Mustang rear end fabbed under it, I'll get pics of it when I get it back. I was offered the option of having my spindles lengthened to gain some turning radius but he was leary about doing it on a street driven car. Go ahead and lighten your car in this way if you want, if it's a drag car you'll love it, I don't mind it but I'm not going to kid you and tell you that this is a good general weight reduction mod, it is for the hardcore only.
Old Aug 17, 2009 | 08:17 PM
  #415
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have read similiar stories regarding the coil overs. That is why I did not go that route. I went with the tubular K-member and a-arms to get clearance for my modified exhaust system. I'm sticking with the factory steering box and springs. If I lose 20 pounds or so in the process so much the better.
Old Aug 17, 2009 | 08:44 PM
  #416
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
hardcore guy here, but its for sure streetable.
you want to cut the spindles, or buy a set of racecraft fabbed units.
lengthening them will make the issue worse.
Old Dec 18, 2009 | 03:43 PM
  #417
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I've been wanting to do one of these for awhile. There are a few more areas that you could use to lessen weight, but they are extreme and permanent modifications.
You could remove unnecessary bracketry up front, as well as 'windowing' the steel around the strut towers. This would require reinforcing the strut tower and a great deal of engineering and welding knowhow. I would NOT recommend this to someone who didn't know what they were doing and why, it's pretty extreme and can shave some weight, and can also junk a car and driver if you do a hackjob. Might be best to stick with less essential areas.
All plexi/Lexan. Expensive? Yes. But that hatch weighs a ton! So does the windshield.
LS engine or aluminum block.
Unnecessary steel in the back. You know, the piece in the wheelwell that just hangs behind the tire/wheel...would require a bead of weld put in it's place over the seam and some seamsealer and underbody coating to keep from rusting though. Bracing on the inside of the car not necessary for structural integrity (steel around speaker mounts, etc)
Remove the passenger door, cut off the skin and weld a brace/crashbar to the inside of the doorjamb. Then weld the skin in place. Extreme, but would save a ton of weight. You could do the driver's side too if you didn't mind being called Ricky Bobby.
What weight are you at now?
Old Dec 22, 2009 | 10:51 AM
  #418
MikeC.86Roc's Avatar
Props to you for your quest. Over the years, I personally given up on the thirdgen due to heavy weight and jumped ship to the Corvette family. I really enjoy seeing you guys with determination and vision with cool projects like this! Good luck!
Old Dec 30, 2009 | 12:21 PM
  #419
I was talking with my fabricator after getting a 95 Mustang rear end fabbed under my car and he said one of the funniest things I've ever heard about Camaro's. He said "I wish I could put a Mustang floor pan in one of these" I asked "why what would the point be" he pointed to the floor pan and the angles and such and said "because these look like they were designed by space aliens".
On that note, my car is probably heavier than last year now due to the differential, but man was it worth it! It's so nice to not have to worry about breaking something at the track. If I get a chance to weigh it this spring I'll post up what I ended up with.
Old Jan 26, 2010 | 06:07 PM
  #420
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
u got pics of the installed rear? howd u fab up the tq arm mount? i swapped in a ford 8.8 about 5 months ago outa a 95 crown vic. 28spline axles, rebuilt carbon fiber clutch pack posi, disk brakes, ARP cap studs, ford 3.55 gears, and a moser support girdle.
just wanna see how u pulled it off. the ford 8.8 is alittle heavier than the 10/9bolt. but not much. 8.8 weighs as much as a 12bolt i believe but less than a DANA and less than a 9".
Old Jan 29, 2010 | 07:18 PM
  #421
I see you already found my other post My fabricator says these rears break about as often as the 9 bolts (meaning that beefed up they're just about as strong), they run quieter, they're lighter, and it was WAY easier to fab off of for a third gen. There was quite a bit of difference with the 9 bolt that came out of my car, I really should have taken pics side by side.
Old Jan 30, 2010 | 05:07 PM
  #422
Car: 87 TA clone
yes i did
your saying the ford 8.8 breaks as much as the 9bolt?
Old Jan 30, 2010 | 07:40 PM
  #423
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Originally Posted by customblackbird
yes i did
I think he meant 9"...
Old Jan 30, 2010 | 08:35 PM
  #424
Car: 85 Camaro IROC
Engine: 5.7 TPI
the 8.8 is standard equipment on an exploder, which weighs a ton more than a camaro, and is capable of off roading with big tires, so it will be a lot stronger than a 9 bolt, which is only slightly stronger than a 10 bolt.
a 9" on the other hand, is a different matter
Old Jan 31, 2010 | 02:23 AM
  #425
Breaks about as much as the Ford 9, which isn't very often. He is a professional drag racer and fabricator, he goes through a lot of stuff.
Old Jan 31, 2010 | 10:18 AM
  #426
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I remember seeing someone was cast iron welding torque arm mounts to 8.8 Ford rears.
5.0 mustang guys all the way through late model mustangs, really like a rear suspensions kit made by Griggs racing. It basically adds a torque arm to a 8.8 and converts a mustang to a suspension like ours for handling and performance.
Here is a picture of one installed:
it comes from this article on the 2006 Vortech Mustang
http://www.mustang50magazine.com/fea..._gt/index.html
I always thought that people with some welding experience could build a torque arm for our cars that uses the locating like the Griggs at one end on an 8.8, and then mounts the other end to a trans cross member like some of the cooler racing torque arm made for our cars already.
You could finish it up by cutting the mustang brackets off of the tubes and welding ones like ours from a donor.
The benefit of doing this would be weight improvement over a 9". The weight of the torque arm is going to be there no matter the rear you choose. The parts for 8.8 Ford rears are prolific and cheap. An 8.8 is basically a copy of the GM 12 bolt, using some of the same bearing part numbers even.
As to its strength, I have seen 9 second mustangs on completely stock 8.8 rears, and low 8 second cars on 8.8's with spool/axle upgrades. There are 7 second cars in the NMRA still running 8.8's.
When I pulled my Currie 9" off of its pallet in 2001 we had to make space for in in our shop. We had to move several 8.8 rears that were for mustang projects we were already working on. The weight difference was incredible.
Old Jan 31, 2010 | 03:06 PM
  #427
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
So people mentioned that the LT1 starter will work on a standard 305... is this true? No changing of the flywheel or anything? Wiring isnt an issue if thats all that is required. I also heard some v6 S10s had some factory mini starter that was stock. Anyone know anything about this?
Was the alumium water pump factory and any cars/trucks with a SBC? And whats this short or long water pump from the aftermarket? Which one do we need to work with the factory serpintine setup?
Old Feb 1, 2010 | 12:19 AM
  #428
Ask for the starter from a 1998 S10 2wd 4.3, should be a mini starter (it's what I run on my car). A chevy full size with a 454 from the late 90's was also a mini starter according to one of my dirt track friends. We have the reverse rotation long shaft water pump stock on the serpentine cars. I've heard you can make the short style (like on the corvettes) work by using a pretty basic spacer, one of the members on here has that setup. The Vette pumps are pretty cheap and aluminum, I have one in the garage but have yet to swap it on for need of the spacer.
Old Feb 1, 2010 | 12:28 AM
  #429
duplicate
Old Feb 1, 2010 | 01:59 AM
  #430
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Having internet trouble?
I didn't know 'vettes ever came with alum. pumps. A long time ago when I was searching for a cheap aluminum pump, I went to Napa and asked what the replacement 'vette pumps were made of (hoping it would be my cheap route to an aluminum pump), and I was assured they were iron.
speedwaymotors.com sells the spacers you need: http://www.speedwaymotors.com/Water-...ee-V6,607.html
Old Feb 1, 2010 | 11:25 AM
  #431
iggy1991's Avatar
I looked those spacers up on summits website but Id rather not spend another 35 dollars plus the cost of the pump if i can help it. im gonna try to make my own and compair the 2 side by side to get the distance required. Which I found out is almost exactly an 1inch. maybe a little less for the use of an extra gasket but not worried about that.
The water outlet hole is a bit smaller than the factory pump too but thats not a big deal.
Attached Thumbnails My late night quest for 2,800 pounds......-2010-02-01-21.37.51.jpg
Old Feb 1, 2010 | 01:50 PM
  #432
iggy1991's Avatar
The s10 starter is the offset bolt pattern not for my 305. The Lt1 starter looks like it will bolt right up but the drive gear is larger and has more teeth 11 vs 9 for the standard 305 starter. Anyone have any insight on this?
Attached Thumbnails My late night quest for 2,800 pounds......-2010-02-01-14.45.27.jpg
Old Feb 3, 2010 | 01:33 AM
  #433
I'm rather certain the LT1 starter will work fine, may need shimmed to make it work right. If it doesn't, then check out the big block mid 90's chevy starter and see if it's the same as the LT1.
I have a stock Federal Mogul corvette water pump, and I promise it's aluminum. I was told it was the stock replacement and it says right on it reverse rotation but I don't know what year it's from.
Old Feb 3, 2010 | 09:17 PM
  #434
iggy1991's Avatar
The big block starter looked like a HUGE diesel truck starter. Im gonna try the lt1 starter once i get into the engine work
Old Dec 9, 2012 | 09:34 PM
  #435
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
2930 without my 200lbs butt, fiberglass hood,aluminum heads,front and midplate with engine limiters,S&W anti roll, bar 4 gal cell light weight carpet,draglite wheels, ac/heat delete,power steering delete, dash is just a shell with gauges. corbeau seats. 8point chrome moly cage with sfc's,drive shaft loop. looking to put a bmr tube kmember and lower control arms with manual rack and pinion and strange drag brakes. supposed to remove 100lbs.
Old Dec 10, 2012 | 05:53 PM
  #436
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
k member and a arm setup is worth in the 30's if you go with race stuff. my rack setup and brakes were in the 30's each as well. should get close.
Old Dec 10, 2012 | 05:55 PM
  #437
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
full interior w aluminum seats and cage, best i can do is 2995.
still have front bumepr support and stock gas tank. glass hood.
ive whiddled everywhere. would like lighter, but dont wanna cut up car right now. im taking the radio, speakers and all wiring out shortly. that will get me around 10 pounds.
Old Dec 10, 2012 | 06:15 PM
  #438
JERRYWHO's Avatar
100lbs. or more, My car has a PA racing C/M k member and A arms, Koni coil overs and wilwood aluminum hubs and brakes and if I remember corect at was like 115lbs. I can get you the weight in the next week or so when I part the car out.
Jerry
Old Jun 7, 2013 | 10:49 PM
  #439
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally Posted by SSC
If you wanted to go crazy some racers claim 1/8 lb drop from changing chrome lug nuts to standard replacment type.
i went from chrome steel all the way to aluminum. i saved a ton.
hadnt read this thread in a while and was scanning through it
Old Jun 8, 2013 | 03:56 PM
  #440
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i just weighed a chrome lug, the factory lug missing the plastic cap and,a standard lug you accually save 14 oz going from chrome to standard and 1lb from factory to standard
its 34oz. for the set of factory missing plastic caps
32oz. for chrome
18oz for standard
i should really get a matching set of lugs for my car
Old Jun 8, 2013 | 06:03 PM
  #441
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
32oz. for chrome
18oz for standard
i really do have billet aluminum lugs.... i dont know the weight savings, but in my hand, the whole set of aluminum is lighter than a couple of steel ones.
Old Jun 8, 2013 | 09:24 PM
  #442
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
were do you get aluminum lugs?
Old Jun 9, 2013 | 11:24 AM
  #443
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
They're all over eBay. I settled on a $50 aluminum set after I couldn't find a set of titanium lug nuts for less than $300.
Old Jun 9, 2013 | 03:28 PM
  #444
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
quality aluminum lugs are going to run you in the 200 range. team z and racecraft carry aaron p lugs and champion wheel sells their made-in-house lugs. both are very similar.
Old Jul 24, 2013 | 11:16 AM
  #445
Ingram78's Avatar
Car: 1985 firebird
Jerry
Parting it out ? Sell me your front end assembly ! Lol
Old Jul 24, 2013 | 12:26 PM
  #446
JERRYWHO's Avatar
O.K.
Old Jul 24, 2013 | 01:14 PM
  #447
Copperhead's Avatar
Originally Posted by ChrisFormula355
. . . I have no pop up headlights (replaced them with "driving" lamps . . .
What did you do here? Have any pics?
Old Jan 8, 2014 | 10:22 PM
  #448
lancefits3's Avatar
3195 all metal, electric windows. stock seats. stock glass. no cage currently. with 2nd fuel cell for nitrous. the nitrous kit bottle etc... full gas tank premium, full 1 gal cell race fuel 2 fuel pumps btw. th400 ford 9inch still currently have rear bumpersupport and stock seatbelts. engine is hardblocked up to freezeplug holes.
this is with stock front k member and arms as well. complete heavy aftermarket rear suspension. and both sway bars..
stock dual fans stock rad
stock powersteering box no pump with skinny's. id never do a s10 box too many turns lock to lock. 2 1/4 lock to lock is nice when you get loose on the street trying to make a pass.
that's also with me in it! englishtown scales
using felt carpet helped alot.
gutting dash.
electric waterpump
front coilover set up
!!!wheels!!! hoosier front runners 7 lbs lighter each over a radial skinny!!! on some race stars
rear rims prostars with no tubes 26x10
removed rear seats. and rear seatbelts ( a decent chunk of weight)
the center console helped alot. megashifters are heavy as hell id say go with a nice 1/4 stick ( if auto)
this year i will be going to gut my doors (keeping electric windows)
remove front sway bar
remove rear bumper support
tubular k and arms
removing stock gauges (since i have like 7 other gauges) im going to mkae my own cluster to save weight on mounting cups/ stock gauges i dont use.
possibly an aluminum dash pad mainly for looks
aluminum center section for the 9inch with spool
remove stock front seatbelts, and seats ( going with 5 pt and leather 4thgen seats) imo way lighter by feel.
couple other things i may try, but i am adding
6pt cage, and aluminum drag wing ed quary style
Old Jan 10, 2014 | 07:24 AM
  #449
lancefits3's Avatar
anyone have any pictures of a gutted door, or in the process of gutting a door?
any other ideas on making our cars lighter?
Old Jan 17, 2014 | 12:06 PM
  #450
unknown_host's Avatar
Car: 1989 Iroc Z L98
I have been working on a few things to take weight out of my street/strip car. In my opinion, you have to have a vision of where you want to go with weight reduction for it to turn out right. I am cutting brackets off the car that are not needed while I recarpet, and have been putting them in a 1 gallon zip-loc bag so I can see the weight savings . I am recarpeting because I am moving my battery to the rear of the car, etc, etc, etc.
Here are a few places I have hit so far that may or may not be obvious:
Converted to manual S10 steering box from power steering (removed power steering lines, power steering box):
Converted from stock serpentine setup to an electric pump (removed both large heavy serpentine brackets, smog pump, power steering pump, AC compressor, cast iron water pump, and tensioner):
Removed rear carpet and jute padding, installed lightweight insulation:
Installed lightweight "Wal-Mart" carpet, moved battery to the back of the car:
Installed push/pull switch when I converted to a rear mounted battery:
Pulled the interior plastics while recarpeting (the plastics are going back in), removed tar/jute pads (each of these pads probably weighs 4-6 pounds):
Cut off unnecessary brackets. I am still working on this, there are 2 under the rear carpet and 2 behind the rear plastic near the pull down assembly:
Pulled the plastics, removed two 6x9 speakers, adapters, extra "monster" wire from the previous owner:
Converted from stock factory seats to Summit Racing plastic seats with Jeg's covers (this was a huge weight savings for the price, I want to say my stock power driver's seat was 53 pounds and my passenger seat was 30, I want to say it saved 60-70 pounds alone) :
Next up I will be removing the passenger area carpet and plastics and looking for areas to reduce weight.
