Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
custom gfx
Old Oct 29, 2004 | 01:42 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
custom gfx
alright, i decided to make custom ground effects for my car and im wondering exactly how i go about this? what do i use? and where can i get these materials?i dont wanna hear that its a dumb idea, just toying with it.Also, this is also goinjg to be applied to my friends Buick Century, so he is the guniea pig.....any help would be appreciated.
-Adam
Old Oct 29, 2004 | 01:57 PM
Mathius's Avatar
Re: custom gfx
-Adam
Usually they're made in clay, and then a mold is produced and the urethane is poured into the mold.
'Course there are alternatives. You could make one out of aluminum if you have a tig welder or want to try welding aluminum with a MIG.
I suppose you could try to setup something in cardboard, or foam and then fiberglass over that.
Ede, you seem to be the resident metal expert, how much weight do you think would be added to a camaro if you removed the stock Camaro gfx and attempted to make them out of 20 gauge or so steel? The pros would be no more body lines if you welded it all together. Cons of course is weight and dents and/or lack of flex.
How 'bout aluminum?
Mathius
Old Oct 29, 2004 | 02:02 PM
tsb09000's Avatar
Car: 85 camaro
Engine: 2.8 :(
Transmission: auto
I am also in the process of making my own set of ground effects for my camaro, for the front anyway. I know of two ways but since I haven't tried either yet, I can't say for sure which would be better.
Anyway, the way I started is with your basic 4x8 sheet of styrofoam insulation. I cut shapes out using a electric fish knife then glued them together with some old spray adhesive. To get more of the final shape I used a drywall sanding board...works great! That's as far as I have got but the next step would be to use kilz primer on it (so the resin doesn't eat the foam away), then just start fiberglassing.
Here's a link that might help explain it better http://www.stormaddicts.com/forum/viewtopic.php?p=2179
You might also look at my post on the ground effects that I started.
Another way I've seen is to use wood to get the basic shape then stretch fleece over it and move on to resin and fiberglass, just like you would a fiberglass speaker enclousure. Of course you would remove the wood for weight reasons.
Here's the link I found for this method http://www.sounddomain.com/id/highvoltage77
I hope this helps and keep us posted
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
