Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fly wheel/flex plate shatter shield
Old Oct 30, 2004 | 08:23 AM
oil pan 4's Avatar
Car: 89 Firebird
I have some .110'' thick 5xxx or 6061 Aluminium alloy would that be thick enough to make a safe shatter sheild for a stock bell housing?
It would be for a TH700 and T-5 camaro transmissions.
Old Oct 31, 2004 | 08:32 PM
Rage13's Avatar
Car: 89 Firebird
.110" aluminum? i was thinking about using 1/8" or 1/4" steel plate for mine.. i wanna keep my feet
Old Nov 1, 2004 | 03:15 AM
oil pan 4's Avatar
Car: 89 Firebird
Yea I guessed that Al would be a little weak.
I have .100'', .110'' and .120'' thick 4-Al, 6-V heat treated Titanium alloy.
Would that be strong enough?
Old Nov 1, 2004 | 10:39 AM
83 Crossfire TA's Avatar
There’s 2 ways of looking at this… putting anything in there is better then nothing, OTOH, unless it’s SFI certified it isn’t going to be legal as per any sanctioning body no matter what you do (well, unless you pay to put it through their certification process).
Second, if you use anything heat treated you’ll have to anneal it to bend it or weld multiple pieces, and if you expect it to be as strong as pre “fabrication” then you need to get it re heat treated after it’s completed.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
