Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
boring the intake
Old Dec 5, 2004 | 11:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
boring the intake
whats the best way to bore out and port match the plenum/runners/base?
i bought a intake base that is ported to afr heads, and i want to clean it up some but never done this before. and i might as well match it to my runners and plenum huh?
Old Dec 6, 2004 | 04:52 AM
ede's Avatar
ede
extrude hone, die grinder w/carbide burr
Old Dec 6, 2004 | 12:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
so i can use an extrude hone or a die grinder with a carbide tip?
Old Dec 6, 2004 | 02:06 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I use a die grinder with a carbide tip. Pretty much use the felpro gasket as a guide I usually mark it out the extra material then go back and scribe it in with a sharp edge. Then I know how far to take out exactly.
Try not to get to carried away with the passages near the center of the intake. If you try to straighten the passage out to much there then you'll go through the wall. But you can take a lot of material out, I did make the mistake of going to far once.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
john204481
Sep 7, 2015 03:22 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
