Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Is there any way to improve on the stock dual snorkel system?
Old Dec 25, 2004 | 05:57 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I was looking at LS1 aftermarket lids and notice how they have a larger hump and the thirdgen dual snorkel is has a very thin height. What kind of materials would you use to make a custom dual snorkel lid? Im wondering if its possible to raise the height on the dual snorkel system to allow more air into the entire setup? Ideas? Opinions?
PS: I realize this is someone who fabricated a LS1 lid on a LT1 4th gen. Just using it for the lid reference.
LS1 lid example:
Attached Thumbnails Is there any way to improve on the stock dual snorkel system?-pictures-form-digital-010.jpg
Old Dec 25, 2004 | 06:22 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I was thinking the same thing as you. I am planning on making something out of polished stainless. I already did the hogging out of the air box, but I want to extent it down to the opening in the nose. Although that portion I wont do in polished stainless, because you wont see that part.:rockon: (FYI my Z is out of the paint shop and is awsome once more.)
Old Dec 25, 2004 | 08:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
How much clearance to the hood is there above the tubes? Might want to check that with modelling clay first to see how much room is available for larger tubing, and go from there. Of course, you could always remove some hood bracing for extra clearance.
Old Dec 25, 2004 | 08:18 PM
MYBLUZ's Avatar
Engine: Blown 383
If I remeber right the underhood padding sits right on the lid. So, removing that and some braces should work out good.
Old Dec 25, 2004 | 09:02 PM
pasky's Avatar
I don't have any of the hood under padding, i'll have to check that out.
Old Jan 14, 2005 | 09:12 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I'm also interested in this.
Kory
Grant2k
Jul 10, 2018 04:01 PM
onefreakz
May 14, 2018 12:15 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
NWAsonoma
Aug 18, 2015 05:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
