Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
DFI panel done
Old Dec 27, 2004 | 06:20 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
DFI panel done
Check out the panel I made for an LS1 Trans Am. It goes where the heater used to go and all the wires exit out the back. It can be removed and used to run the engine stand alone like on a dyno or used in another car.
QUESTION- how can I make the alternator work on this car? It has a 4 pole connector on it, what's the simplest way to wire it up to charge the battery?
Old Dec 27, 2004 | 07:06 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Awesome job serpent!!
Old Dec 27, 2004 | 07:12 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Re: DFI panel done
lets try bring it here
lol looks good dude
Old Dec 28, 2004 | 04:41 PM
TexasLT1's Avatar
Car: '92 RS
Re: DFI panel done
Chris, it's probably similar to the LT1 alternator, as it also has a 4 wire connector, but only 1 is used. might try that?
Old Dec 28, 2004 | 05:26 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I looked in the service manual, it shows one wire just like you said, but the funny thing is that it goes to the ECM and it appears to get grounded by the ECM to enable it. I'm still researching it but so far it seems the 4 connections are for different types of configurations. I think one wire is used when an idiot light is used, anbother for the ECM and another when neither are used.
Sure aint like the old days!
Old Jan 3, 2005 | 07:48 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
i dont remember what pin it is, but one wire on there must get ignition to allow the battery to charge. if you hook up the wire to constant, it will drain the battery when the car isnt running
Old Jan 3, 2005 | 10:10 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
there's only one sure thing to do- look under the hood of a few LS! equipped cars and see how it's wired
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
efiguy
Sep 27, 2015 01:30 PM
