Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welding floors and such
Old Feb 6, 2005 | 02:18 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
whats the best way to go,I got a 90AMP mig welder that requires no gas and only a plug it uses some kind of flux wire.Is this type of welder ok for doing floor pans ,and some sheet metal patch work? arc welders seem to go cheap are they better for this kind of stuff?
thanks
Old Feb 6, 2005 | 09:39 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
mig is the best but most would recommend gettin a mig welder that can be use with gas and regualr wire and not flux-core wire. the flux-core wire youll have to chip/wire brush off the slag that is left over from the flux after its burned up.
Old Feb 6, 2005 | 09:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which exact brand/model of welder is it?
You should be fine, it won't look as pretty as if you used gas (you can usually buy a conversion kit so you can use gas with it...)
Arc Welders are cheaper for a reason, the scope of what you can weld with them is smaller, usually just thicker stuff....
Floor pans are fairly thin, 18AWG maybe? I have no idea, no experience...
Yea, that welder should be fine for sheet metal, if you can, upgrade to gas rather than flux-core, it's easier to work with on thinner stuff, and prettier.
Old Feb 6, 2005 | 10:58 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I also bought a cambell houseford? 75amp arc welder i was told arc welders give a stronger weld.
Old Feb 6, 2005 | 11:01 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yes arc welders do but on thicker metal youll most likly blow thru the metal with the arc welder enless you have good practice with it.
Old Feb 6, 2005 | 11:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
haha, that's kinda odd...
You bought a cheapo unit of each, you coulda saved some $ and bought a better gas mig, gotten the best of both worlds, and been essentially able to weld anything...
(ie, for the same money, buy a gas MIG that's bigger, been able to weld at higher currents, etc.)
Basically now, anything you could weld with the arc welder, you can weld with the MIG. So you probably won't use the arc welder much... I would return the stick welder if you still can, IMHO.
Old Feb 6, 2005 | 11:30 PM
rjmcgee's Avatar
I had better luck running the flux wire in my mig welder when I was welding my SFC under the car.
Old Feb 7, 2005 | 04:43 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I actually returned the 90amp mig because it was cheap piece of junk.The plastic handle began to melt when I tried it on a piece of scrap.I went with the arc because it is kind of a dieing art.I'll pratice with it and get good.I was also told that arc welding is alote stronger then most.
Old Feb 7, 2005 | 11:01 PM
83 Crossfire TA's Avatar
The only real way to do body sheet metal is with a gas shielded MIG. Flux core and arc are not controllable enough (put too much heat into the weld/too much penetration) for body sheet metal.
Stick welding really isn’t any stronger then mig, strength is mostly up to technique and prep.
Old Sep 19, 2012 | 06:10 PM
nickdiesel's Avatar
Car: 1988 Camaro Convertible
Re: welding floors and such
Use 6013 its an easy sheet metal rod 3/32". I would start with the welder set around 60 and move up as needed. I would also reccemend circular motions when welding. This rod should give you less headaches. Shorter welds at a time so you don't blow through or warp it. Make sure metal has paint removed and metal is butted up nicely.
Old Sep 20, 2012 | 04:35 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
your advice is about 7 years late
Old Sep 20, 2012 | 10:16 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Old Sep 25, 2012 | 01:01 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
AND the flux core can be used...18Ga Sheet steel for a floor pan is hvy enof to hold up if you doing patch work,
it take using the flux core wire. and getting the welder set up to the feed rate..there not all the same..after a few time using it. ya get to know, the low setting Hi setting and feed speed to set it at..
stuff your not going to see or show, like mini tubs floor pans it's fine.
seat rails. and small fixes all the way up to 1/8.... anything more..get somthing Better.. But I love mine... (90 amp flux core wire feed)
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
