Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
got bored again, mini tub time
Old Dec 4, 2011 | 09:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3 hours and 5 sawzall blades so far, having to work around the seats and roll bar took a little longer than anticipated. Probably won't mess with it again until later this week.
Also having previously boxed the front lower area and cutting out the bumpstop area and welding in sheet metal will add to the amount of time spent on this to finish cutting everything out. The rear arm rest metal will be full removed as well to save a little weight.
Old Dec 4, 2011 | 10:30 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: got bored again, mini tub time
How much for you to do this to my 86!
Looking forward to this, How I wish I had a welder. Maybe this Xmas.
Old Dec 4, 2011 | 10:42 PM
xpndbl3's Avatar
Car: 1984 Z28
most shops charge in the $1000-1200 range to do a mini tub.
Ya my 220 volt lincoln will fly through this when I get to this point. Didn't want to spend anytime pulling out the seats or carpet just yet until I get to that point in cutting.
Old Dec 5, 2011 | 02:03 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
It sure is nice to have the extra room for larger tires.
Old Dec 5, 2011 | 10:23 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'll continue to make it happen on tt5's and 275's!
Old Dec 6, 2011 | 04:39 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I'm doing the same thing right now to fit 335's. Nice work so far...I'm not cutting into mine quite that far...I'm trying to keep the seat belt anchors and some of the arm rest bracing...lol
Old Dec 6, 2011 | 05:29 PM
xpndbl3's Avatar
Car: 1984 Z28
arm rest has to be cut out to do mini tubs, no way around that. No clue where the seat belt bolts are either, but I'm pretty sure those will be gone also. I still haven't cut far enough into the openings either, still another 1" at least to go.
Old Dec 6, 2011 | 07:13 PM
406TPI's Avatar
Car: 1985 IROC-Z
If you use a conventional pre-fab tub the arm rest brace has to go. I'm not using a normal tub for that very reason plus my tires are only 26" diameter.
Old Dec 7, 2011 | 01:43 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
I prefer the mini tub even though I run TT5's. I like the tires to sit under the body a bit more for a better appearence and it gives you the room to grow the tire size if needed down the road.
Old Dec 7, 2011 | 01:53 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
I agree^ so is it easier to adapt a universal wheel tub kit to work or buy the 4th gen wolfe kit and make it work?
Old Dec 7, 2011 | 04:40 PM
mw66nova's Avatar
Engine: 7.0L
My tires sit under the car just fine.
Old Dec 7, 2011 | 04:56 PM
xpndbl3's Avatar
Car: 1984 Z28
be even better with a mini tub
Old Dec 9, 2011 | 04:16 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You better get a plasma cutter Lol
What are you going to do with the interior when it's done?
Old Dec 9, 2011 | 10:39 AM
xpndbl3's Avatar
Car: 1984 Z28
carpet the tubs, cut the panels to fit
Old Dec 11, 2011 | 02:42 AM
BBCpoweredZ28's Avatar
Are you using the Wolfe kit or universal tubs?
Old Dec 11, 2011 | 02:56 AM
xpndbl3's Avatar
Car: 1984 Z28
wolfe kit and wolfe spring kit
they don't make a universal mini tub kit that I'm aware of....? The universal kits are full tubs and not something I need since I doubt I'll ever toss on that huge of a tire.
Old Dec 11, 2011 | 02:32 PM
SOLOMOTORSPORTS's Avatar
Car: 88 GTA
Engine: 99 LS1 346
I am looking forward to seeing how it turns out.
Old Dec 11, 2011 | 05:36 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
If i did it again I would have extended my rear most part of the tub lower into the wheel well like a built in mud flap to help prevent all the rubber that accumulates under there. With the back of the tub lower it would catch all the rubber instead of my bumper cover and area that my crash bar bolts too. It sure suck picking the rubber out of there.
Old Dec 12, 2011 | 09:21 AM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Ought to turn out real nice.
Tip: When you go to locate and weld in the spring adjusters, put the springs you're going to use on the rearend, put the spring adjusters on top of the springs and jack the rearend up. Make sure that at ride height the springs are straight up and down. If you need to trim the plates to get them to mount where you want them, feel free (I had to). Once you're happy with placement, using the rearend to locate them as above, tack them in, pull the rear out of the way and weld them up! You might want to put some tape, etc. on the threaded portion to prevent any MIG slag or trash from getting on them and making life hard.
I can't take too much credit for the tip, Madman and co told me that it would be easier to do it that way....
Old Dec 17, 2011 | 07:02 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Axle/Gears: moser 9" with 411 posi
i may be doing this soon as well. dont really need that much bigger of a tire. i just want to get it tucked in a little further
Old Dec 17, 2011 | 10:06 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Gotta follow this!!
Old Dec 17, 2011 | 10:39 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Don't scratch that Award-Winning-Paint!!...
Old Jun 5, 2012 | 03:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Plenty of clearance now....
Some updated pics from thirdgenfest this past weekend.
Old Jun 5, 2012 | 04:23 PM
mw66nova's Avatar
Engine: 7.0L
makes me want to do this...
Old Jun 5, 2012 | 04:42 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Me too. I know I will eventually, but this makes me want to do it soon. And I already have enough stuff I want to do now.
Old Jun 5, 2012 | 06:18 PM
mw66nova's Avatar
Engine: 7.0L
hey i just noticed the name on the window, looks great steve! the font looks familiar
Old Jun 5, 2012 | 07:43 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
when i did mine i cut into arm rest brace,REMOVING just enof to move the wheel well inward almost 3" and made the inside tubs out of 18ga sheet. running right up to the back of the inside plastic. about 1/2 or less away.
saving up to just get it back halfed in a year or 2 (hoping) STILL SNOWBALLING!
Old Jun 5, 2012 | 07:55 PM
was thinking about somthing like that last week.
i use a brush to remove most of the rubber, now.
Old Jun 5, 2012 | 07:58 PM
Car: 91 firebird
Axle/Gears: 4.30
Looks great. I have the Wolfe kit in the garage just been to lazy to do it
Old Jun 5, 2012 | 08:06 PM
Car: 91 firebird
Axle/Gears: 4.30
Any pics of the finished wheel wells?
Old Jun 5, 2012 | 09:01 PM
xpndbl3's Avatar
Car: 1984 Z28
haha thanks man, ya I really like how they turned out, just the right size that they're not annoying on the windows.
Old Jun 6, 2012 | 05:49 AM
mw66nova's Avatar
Engine: 7.0L
How tall is the letters? I need to redo mine as it was too big...
Old Jun 7, 2012 | 10:17 PM
xpndbl3's Avatar
Car: 1984 Z28
they're just under 2" tall
Old Jun 8, 2012 | 05:23 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Drag car
Old Jun 9, 2012 | 07:46 PM
xpndbl3's Avatar
Car: 1984 Z28
haha thanks Scott, certainly looks a lot better with the tires tucked in more and plenty of room all around if I ever go bigger.
Old Jun 9, 2012 | 08:48 PM
mw66nova's Avatar
Engine: 7.0L
15x12 ftw!
Old Jun 9, 2012 | 09:08 PM
xpndbl3's Avatar
Car: 1984 Z28
i wonder how these tires would look stretched on some wider rims....hmmm. Plus billet specialties has those black anodized version rims. Who's got a bunch of cash laying around....?
Old Jun 9, 2012 | 09:19 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
When you find out who does have a bunch of cash laying around let me know too.
Old Jul 11, 2012 | 04:50 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Any progress?
Old Jul 11, 2012 | 05:02 PM
xpndbl3's Avatar
Car: 1984 Z28
I'll get some finished pics when I get a chance, just bought a complete light grey interior and was hoping to get that all cut out nicely before posting pics. Then I need to figure out who sells flat pieces of matching carpet to carpet the mini tubs as they're just painted flat black right now to stop from rusting. Anyone got an idea who sells it? Home depot and other hardware stores only sell outdoor carpet that looks like crap, and went into a michaels craft store but nothing in there as well.
Old Jul 11, 2012 | 07:53 PM
mw66nova's Avatar
Engine: 7.0L
can you get just carpet material through ACC?
Old Jul 11, 2012 | 09:13 PM
  #42
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I got black carpet material through Parts express I think. I got a little bit so I could cover the front kick panels from grey to black to match my newark auto carpet.
I love full mini tubes. But I also like full aluminum interiors lol. I was able to fit a 295/65/r15 under my wheel wells with no real mods. Just a put together rear weight jack kit and a ford 8.8 rear lol.
Old Jul 30, 2012 | 09:56 AM
  #43
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Car is looking good with those tires tucked man! I bought carpet through this company and I actually cut a small piece of carpet that would be behind a panel and sent it to them and they matched it for me and sent me a sample back. Color was very close. Also put up pictures when done cant wait to see how the interior comes out. Also sorry if this link is too late and you have already figured this out
http://www.automotiveinteriors.com/c...out_carpet.htm
Old Aug 21, 2012 | 12:32 PM
  #44
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
You think 335 would fit ok in a mini tub? Also where do the doings and shocks mount? I want to do this with air ride. Think there would be issues?
Old Aug 21, 2012 | 08:24 PM
  #45
xpndbl3's Avatar
Car: 1984 Z28
can't really mini tub and keep the same size as stock diameter springs, you use a 2.5" diameter spring to gain the extra space. I ran 28x12.5 ET streets for a while which were 12.6" section width, how wide are the 335s? I just did some cutting/welding and kept the stock tubs for the most part.
Old Aug 22, 2012 | 08:31 AM
  #46
406TPI's Avatar
Car: 1985 IROC-Z
I run a 335 tire in my mini tub. Had to use the small diameter QA1 springs, shocks stay in the same location. My 335 toyo R888's are 14" wide.
Old Aug 22, 2012 | 09:34 AM
  #47
BADNBLK's Avatar
COTM Editor
Your a god...
Old Sep 25, 2012 | 07:17 PM
  #48
BOTTLEDZ28's Avatar
Transmission: A4
How close is the tire to the LCA on these car that have these mini tubs installed? Id love to run a deep dish 11" wide wheel on my car but Im concerned that that they will run or hit the LCA.
I currently run a 4th gen rear but will switch back to a 3rd gen rear or possibly have a new rear shortened if it comes to that.
Old Sep 26, 2012 | 05:49 PM
  #49
xpndbl3's Avatar
Car: 1984 Z28
my mini tubs are wider than the rod ended LCAs in the offset location
Old Sep 27, 2012 | 08:09 AM
  #50
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Don't know if you found carpet yet but check out boat supply stores. Stuff matches automotive carpet pretty good.
