Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
X-frame?
Old Feb 16, 2005 | 12:57 PM
NEEDforSPEED's Avatar
X-frame?
would this be a good way to stiffn the car by adding sub frames only in a x-frame config?
Attached Thumbnails X-frame?-c-documents-settings-owner
Old Feb 16, 2005 | 04:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
well i would do the regular straight back way and add the x to it. this will make it even stronger. many race cars with tubular frames do this method.
Old Feb 16, 2005 | 04:11 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
couldnt weld them.. or you would never get the tranny unless the motor came with it.
Old Feb 16, 2005 | 06:09 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Why not just do something like in this thread..
https://www.thirdgen.org/techbb2/sho...hreadid=167803
I think that would get you a similiar Triangle effect but you wouldn't have to worry about blocking trans removal.
Throw in a tough heavy duty Spohn transmission crossmember (like the ones found on his tq arms) and call it done.
