Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Need to Know a Good Way to Block a 4" Cowl for Street use...
Old Mar 1, 2005 | 08:33 AM
kingbabone's Avatar
I've got a 4 inch cowl and would like to make some thing to "plug" the cowl for when it gets moist outside. Any suggestions???
Old Mar 1, 2005 | 04:28 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
cut up a foam block to the correct size. you can buy them at any fabric store. its the same idea as a plug scoop for a race car.
Old Mar 1, 2005 | 05:39 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've never had a problem with rain getting into my engine compartment with my cowl hood. it would have to rain near horizontal for that to be a problem.
Old Mar 1, 2005 | 10:32 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've had issues with mine LOL. Wash the car, pop the hood and a whole chit load of water comes bailing out of it, really makes me made since it's soapy water
I always wondered how well these cowls work, let me tell ya, if you ever get leaves that fall on your car and your going down the road, it's like a shop vac on roids when you get upto speed, the leaves just get sucked up under there quicker than #hit!!
Old Mar 1, 2005 | 11:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
My cowl has the lip to stop the water, and a screen to stop the leaves. I don't know what it would be like without the lip.
Old Mar 2, 2005 | 10:53 AM
kingbabone's Avatar
mine has a lip, but when I open the hood a TON of water gets every where. I think I am going to get a screen made. I am thinking about mounting 3 oil gauges on the top of the lip... you guys see any problems with that?
Mike
Old Mar 2, 2005 | 11:53 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Which brand of hood do you guys have that comes with a lip and or screen?
Old Mar 2, 2005 | 12:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Are you guys referring to a hood like this.
That's a harwood 4" cowl in the picture --> stolen from this thread.
As for mounting gauges that's pretty common. My Glasstech 4" was pre-punched out for mounts on it.
Old Mar 2, 2005 | 05:08 PM
IHI's Avatar
IHI
I actually mounted mine to the hood itself. I believe just about all of the fiberglass cowls come with that lip for ridigity other wise normal road abuse would make it flimsy as helll.
<img src='http://img.villagephotos.com/p/2004-9/824085/Misc.carpics006.jpg' width=500 height=375 img>
Old Mar 2, 2005 | 05:28 PM
Engine: 383 SBC
I should make that a little more clear. My hood was setup to accept the gauge on the hood not on the lip. But I've seen them on the lip or even cutouts into the screen and mounted there.
Here's my GlassTech one no lip in sight.
Old Mar 2, 2005 | 05:55 PM
xpndbl3's Avatar
Car: 1984 Z28
my glasstek has no lip either.
Old Mar 2, 2005 | 06:01 PM
Engine: 383 SBC
I imagine glassteks are just made that way. (Man I butcher'd the name earlier didn't I). Anyways have you had any problems with rain or flexing from not having the lip?
Old Mar 3, 2005 | 12:18 AM
kingbabone's Avatar
I was refering to the lip as the piece that ran under the cowl... My cowl is like the one in the last picture.
Old Mar 3, 2005 | 12:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
By "lip" I meant the overhang towards the windshield at the top of the cowl.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
