Filling holes
Car: 1990 RS coupe
Engine: TBI 305.
Filling holes
I was thinking about shaving the antenna so.
Would JB weld work to fill the hole or do you absolutely need to patch it with a piece of metal?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
this belongs more in body and interior...
you don't really "need" to weld in new metal, but it depends on who you talk to.... want a perfect, "correctly done" job, or something that'll work?
I'm probably going to put in fiberglass mat and resin...
JB weld might work... but probably not great.
Car: 91 firebird
Engine: undecided thinking 383 stroker
Transmission: ??????????
weld and grind if you do it do it right
at the very least weld a patch behind it and fill it so it will last past the 1st or 2nd pot hole
just my
just my
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
